block fitting size
Old Feb 7, 2012 | 09:58 PM
93lsv_turbo's Avatar
Default block fitting size
if someone knows the size of the fitting that goes on the back of the block, can you help me out and tell me what size it is. im in the army and am able to get a hold of all kinds of fittings. thanks
Old Feb 7, 2012 | 10:05 PM
mmcd's Avatar
Default Re: block fitting size
are you talking about for a catch can?
Old Feb 8, 2012 | 03:36 AM
yungkhmer's Avatar
http://i267.photobucket.com/albums/i...DSC_0011-1.jpg
Old Feb 8, 2012 | 03:58 AM
golf-mk3's Avatar
what size tool is that used to remove the factory fitting?
Old Feb 8, 2012 | 04:04 AM
Chugger's Avatar
i believe its a 14mm hex
Old Feb 8, 2012 | 04:09 AM
4cylfiend's Avatar
I bought a bunch of all thread couplings and used one that fit snug (I tapped it in with a hammer) then put a wrench on it and gave 'er hell.
Old Feb 8, 2012 | 04:48 AM
BigMike0147's Avatar
Yeah, it's a big hex.
What I did was get a bolt in which the head fits the hex opening. Then thread two nuts on it and lock them together on the bolt. Then you can just use those and the head of the bolt to back the plugs out of the block.
Old Feb 8, 2012 | 05:21 AM
yea im talking about for a catch can. im not talking about the hex key size that i need. im talking about the actual fitting that goes in the block. just wanted to know if it was like a specially made fitting or if it was something i might find here.
Old Feb 8, 2012 | 07:08 AM
4cylfiend's Avatar
That works wonders as well.
I bought my block fitting kit thru Go-Autoworks. I bought the full catch can setup so the block fittings and plugs came with it.
Link: http://www.go-autoworks-store.com/gocaca.html
Old Feb 8, 2012 | 04:14 PM
BLU CIVIC's Avatar
Track Advocate
i used the fitting from B&R
http://www.brfittings.com/index.php?...&product_id=54
they also make one with a -10an fitting
http://www.brfittings.com/index.php?...&product_id=56
Old Feb 8, 2012 | 05:16 PM
artie89's Avatar
the size of the fitting is M28 to -10 an
Old Feb 9, 2012 | 07:45 AM
There's a couple threads online about using some factory fitting from honda for a barb nipple. That's what I did, but I couldn't tell you the part numbers off the top of my head.
webbs2jzgte
Jan 24, 2009 08:38 AM
1991civicsi
Aug 16, 2006 11:57 AM
Top Ramen
Mar 31, 2006 12:57 PM
brinks
May 19, 2004 03:39 PM
