Turbo LSVTEC- Which Crank?
Old Jan 29, 2012 | 04:16 PM
deguzmanEG's Avatar
Default Turbo LSVTEC- Which Crank?
Hey Guys,
Hoping I could get some input here.
My original set up was a sleeved turbo gsr block. Well upon install of this brand new block it was leaking coolant everywhere so i need to get another block.
The only block I have right now to sleeve is an ls block, can't find any bare gsr blocks around. I'm running a stock ls block in the meantime so i have everything for the conversion anyways.
My question is. I already have the wiseco pistons and GSR eagle rods and woud like to just swap all internals, including the crank over to the b18b. Would this be ok? or am I better off using the ls crank and getting new rods?
Pistons are 84mm 8.8:1 wisecos
Head is stock gsr cams with full supertech valve train.
thanks
Old Jan 29, 2012 | 05:16 PM
Dc4LsTeG's Avatar
EK9
Default Re: Turbo LSVTEC- Which Crank?
Use the ls crank and buy some ls rods
Old Jan 29, 2012 | 05:24 PM
blackeg's Avatar
x2. im using the ls crank and rods in a gsr block. the longer stroke does make a difference.
Old Jan 29, 2012 | 05:56 PM
Turbo-LS's Avatar
1.5 mm of extra stroke doesn't make much different in power for the average setup, run what you have it will still make the power. And it can all go into an ls block but the vtec block is better and offers the crank girdle
Old Jan 29, 2012 | 06:43 PM
SAXON's Avatar
are you asking about power or price
price- its cheaper to just drop it in the ls block with your current parts
power- the ls crank and rods will give some more displacement and possibly help depending upon what you want from the motor
Old Jan 30, 2012 | 02:51 PM
deguzmanEG's Avatar
thanks for you help. I'll probably just keep the gsr crank and everything I already have. Its a daily driver.
Thanks guys
Project_SOHC_EX
Feb 16, 2008 01:54 PM
patrick4588
Oct 18, 2007 12:33 PM
egturbolsvtec
Mar 6, 2006 06:14 PM
