SMOKE PROBLEM Questions
Old Feb 9, 2012 | 09:27 PM
myessay's Avatar
Icon4 SMOKE PROBLEM Questions
OK i was told it was seals n my last post i got a new turbo put on and still people where now saying that my oil pan is tapped to low and when the oil drains its draining in to the oil still n the pain and not in to the space in the pain where here isnt oil witch is causing the oil to back up and not be relased from the turbo. I only get the smoke out of the down pipe when the oil is cold after it warms i dont get the smoke.....
here are some pic of where it was tapped i have a d16z6 and this is the best i can do with the pics since it is on the car still
Old Feb 9, 2012 | 09:28 PM
myessay's Avatar
Default Re: SMOKE PROBLEM Questions
Old Feb 9, 2012 | 09:47 PM
Dc4LsTeG's Avatar
EK9
Pics don't work
Old Feb 9, 2012 | 09:50 PM
myessay's Avatar
i can see them when i view it how do i make them work lol Name:  IMAG0320.jpg
Old Feb 9, 2012 | 10:06 PM
W!d3b0dYr3X's Avatar
OH HELL YA! That is way too low. im surprised you havent ruined the turbo yet. i would suggest fixing it before driving it again if at all possible. No offense but thats the worst i have seen yet.
not to mention in the first pic not only is it way to low but it looks like it comes down and then bends and angles back up at a slight slope which even above the oil level in the pan could cause problems.
Old Feb 9, 2012 | 10:09 PM
Bix VT's Avatar
Your oil return line needs to be higher up in the pan, and the oil should never have to flow uphill. That looks more like an oil drain than a return.
Old Feb 9, 2012 | 10:31 PM
myessay's Avatar
thanks for the reassurance guys on the oil line i will b fixing that soon but with the turbo being low where would i make the tap so that it isnt hangin so low and making the oil drip back into the turbo
Old Feb 10, 2012 | 04:23 AM
Slacker93eg's Avatar
10 Year Member
You want the tap into the pan to be as high as possible, and if possible have the fitting on an angle pointing up at the turbo.
Old Feb 10, 2012 | 08:29 AM
Bix VT's Avatar
Do you have pics of where the turbo sits in relation to the drain? A pic of the whole drain assembly would help.
Old Feb 10, 2012 | 08:34 AM
Turbo-LS's Avatar
Shorten the hose and the bung should be as high up on the pan as possible between two pan bolts so its no in the way. Stop driving it or you will ruin that turbo. Its worse when cold because oil pressure is higher
Old Feb 10, 2012 | 02:55 PM
Whiterice-gsr's Avatar
we went through this in your last post man, we all told u the same thing.
Old Feb 10, 2012 | 02:59 PM
weld a bung as high as possible in the straightest line possible form the turbo. put the bung between 2 of the pan bolts so its not in your way when u want to drop the pan. use a min of -10 or 1/2 inch hose i prefer -12 or 5/8 make sure it doesnt dip before it goes in the pan. the only thing taking the oil back to the pan is gravity so u must let it do its job.
navymike321
Aug 9, 2010 08:29 PM
tvic
Sep 13, 2005 06:33 PM
tony n.
Aug 6, 2005 09:15 AM
90crxzc
Sep 1, 2003 06:28 PM
dirtySOHC's
Apr 3, 2003 05:37 PM
