Precision turbo help.
Old Jan 22, 2012 | 09:02 AM
BoostedEgHatchFl's Avatar
Default Precision turbo help.
I have a JB 6162 going on my built b16. I'm running a -3 feed line. I need to know what size fitting/resistor I need for the top of the turbo.
Old Jan 22, 2012 | 09:30 AM
gringotegra's Avatar
Default Re: Precision turbo help.
I have a 6262 Jb with a -3 feed and no resistor have been running it for over 2 years now with no issues...
Old Jan 22, 2012 | 10:04 AM
Nice man... What size motor is your 6262 on making that much power at just 25 psi.
Old Jan 22, 2012 | 06:22 PM
84mm GSR, 10.5:1 compression helps
Old Jan 22, 2012 | 07:10 PM
welfarepc's Avatar
i also run a journal 6262 with a -3 feed, no restrictor
coming up on three years now no issues
Old Jan 23, 2012 | 07:21 AM
mines13's Avatar
Totally depends on your oil pressure. If it exceeds the recommended maximum pressure, then step up to a .065 That said, you could likely just install a .65 restrictor from the get go, and it would not hurt anything at all. That is the path I took.
fire_king
Apr 20, 2012 02:19 PM
VTEC_PRODUCTION
Oct 17, 2010 12:39 PM
civicgsrturbo32
Mar 21, 2010 09:29 AM
BluRgio
Jan 16, 2007 08:25 PM
teler86
Sep 23, 2006 05:24 AM
