Dry + Boost
Old Jan 20, 2005 | 09:22 PM
romoracing's Avatar
Default Dry + Boost
Hi, I got a question, I got a 99 ex d16y8 and i could get a zex dry kit for 250 and i want to know could i use it when i get my turbo. like drill the intercooler pipe and add the connecter. Or should i got with a wet kit and a aem fuel rail?
Old Jan 20, 2005 | 09:28 PM
donkiman's Avatar
Default Re: Dry + Boost (romoracing)
u should specify your question a littler more. is your motor stock? im assuming it is, if so I dont really suggest you run a turbo and nitrous on your stock block. but id suggest researching how nitrous works and how nitrous works with turbo setups a little bit more.
Old Jan 20, 2005 | 09:34 PM
romoracing's Avatar
Default Re: Dry + Boost (donkiman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donkiman &raquo;</TD></TR><TR><TD CLASS="quote">u should specify your question a littler more. is your motor stock? im assuming it is, if so I dont really suggest you run a turbo and nitrous on your stock block. but id suggest researching how nitrous works and how nitrous works with turbo setups a little bit more. </TD></TR></TABLE>
dont worry about my block i got some stuff up my sleeves. wink wink But i was just curious if i would do any damage to the motor or to the turbo. cuz if dry wont work i can get a wet kit for 50 bucks more. also i know nitrous im new to the trubo stuff so thats why im asking this question
Old Jan 20, 2005 | 09:42 PM
1.8turbolsvtec's Avatar
i had the same set up with a z6 lasted fot 30000 miles with a 35 shot but still melted the pistons and they were coted to i would go with the wet
Old Jan 20, 2005 | 10:06 PM
adseguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by romoracing &raquo;</TD></TR><TR><TD CLASS="quote">
dont worry about my block i got some stuff up my sleeves. wink wink But i was just curious if i would do any damage to the motor or to the turbo. cuz if dry wont work i can get a wet kit for 50 bucks more. also i know nitrous im new to the trubo stuff so thats why im asking this question</TD></TR></TABLE>
Ummm..huh? Do you have aftermarket pistons/sleeves/rods/crank....what? If all you have is exhaust and stupid things like that yes you can blow it up. Done correctly though a nice turbo/nitrous setup will provide more power then turbo alone and can be made reliably as well.
Old Jan 20, 2005 | 11:05 PM
JSpin's Avatar
Default Re: Dry + Boost (adseguy)
are you using an FMU for fuel managment? i could see bad things happening w/ a dry nitrous kit on an fmu setup.
Old Jan 21, 2005 | 07:10 AM
donkiman's Avatar
ya for real if your talkin about 50 bucks making your decision between nitrous systems then im willing to bet your running stock motor. ever heard of head lifting? also what are you using to tune it with? fmu?
Old Jan 21, 2005 | 08:33 AM
RyanEJ8's Avatar
There is nothing wrong with using a dry nitrous kit with turbo. I have my ZEX kit plumbed into the charge pipe.
Old Jan 21, 2005 | 12:14 PM
romoracing's Avatar
Default Re: Dry + Boost (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">There is nothing wrong with using a dry nitrous kit with turbo. I have my ZEX kit plumbed into the charge pipe. </TD></TR></TABLE>
thank you thats all i wanted to know. I have my block rebuilt just got it done. But what i got done on it is my little secert. and im soon going to get bigger injectors vfac and a new fuel rail.
Old Jan 21, 2005 | 12:15 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Dry + Boost (JSpin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSpin &raquo;</TD></TR><TR><TD CLASS="quote">are you using an FMU for fuel managment? i could see bad things happening w/ a dry nitrous kit on an fmu setup.</TD></TR></TABLE>
me too, since the fmu has already increased rail pressure sky high, then on top of that, the dry kit increases fuel pressure
Old Jan 21, 2005 | 01:35 PM
RyanEJ8's Avatar
thank you thats all i wanted to know. I have my block rebuilt just got it done. But what i got done on it is my little secert. and im soon going to get bigger injectors vfac and a new fuel rail. </TD></TR></TABLE>
Why would you use a VAFC on a built block? Get some real engine management.
Old Jan 21, 2005 | 01:45 PM
MooreBoost's Avatar
Just go wet, why take a risk?
Old Jan 21, 2005 | 01:50 PM
RyanEJ8's Avatar
Default Re: Dry + Boost (MooreBoost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooreBoost &raquo;</TD></TR><TR><TD CLASS="quote">Just go wet, why take a risk?</TD></TR></TABLE>
Wet isn't any safer.
Old Jan 21, 2005 | 01:52 PM
wantboost's Avatar
Who is Mr Robot?
Wet isn't any safer.</TD></TR></TABLE>
but most things in life are better wet
Old Jan 21, 2005 | 01:56 PM
RyanEJ8's Avatar
Default Re: Dry + Boost (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">
but most things in life are better wet </TD></TR></TABLE>
Well, I can't disagree with that.
Old Jan 21, 2005 | 03:14 PM
MooreBoost's Avatar
I suppose if you run a blower it isn't any worse. I dont like them for N/A engines because of the unequal distribution of fuel and nitrous.
Old Jan 21, 2005 | 04:57 PM
romoracing's Avatar
Alright then i guess ill go wet. Instead of vfac should i get the hondata s200?
Old Jan 21, 2005 | 06:27 PM
MooreBoost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by romoracing &raquo;</TD></TR><TR><TD CLASS="quote">Alright then i guess ill go wet. Instead of vfac should i get the hondata s200?</TD></TR></TABLE>
I would definitely suggest that over the hack, if you can afford it. The nitrous controls are pretty pathetic though.
Old Jan 22, 2005 | 12:26 AM
RyanEJ8's Avatar
The nitrous controls are pretty pathetic though.</TD></TR></TABLE>
Agreed. I wasn't very happy with Hondata's nitrous controls.
If you place the dry nitrous nozzle 18" from the throttle body you will not have distribution issues.
LS-VTEC-TURBO-EF9
Sep 24, 2008 02:27 PM
speedycrx
Nov 23, 2007 07:41 AM
Spalude
Sep 14, 2004 10:20 PM
NIAScrew2
Jul 26, 2004 11:41 AM
Lewie
Feb 6, 2003 06:11 AM
