Power differences in DP flare locations? help me out
Old Jan 20, 2005 | 02:36 AM
1SlowSi's Avatar
Default Power differences in DP flare locations? help me out
I need to flare my DP to 3", but it seems to be a major pain in the *** after the AC compressor making all those bends. How much power would i lose if i waited to flare it out at the test pipe? (cat location).
Old Jan 20, 2005 | 05:26 AM
DaX's Avatar
DaX
Loved
Community Favorite
Intuition would lead me to believe the sooner you flare the better, but someone with some real knowledge should chime in. I flared directly off the turbine flange.
Old Jan 20, 2005 | 05:32 AM
1SlowSi's Avatar
Default Re: (DaX)
Yeah i wish i could do that but i want to keep the AC. i would do the flare right after that, but its a pain in the *** to do the bends, and if there isnt much loss in power by doing it my way, then thats what im gonna do.
Old Jan 20, 2005 | 05:36 AM
trentepic's Avatar
Default Re: (1SlowSi)
if u run a side winder, or cast wide winder, u can run 3 inch turbo back like me wid ac compatibility!
Old Jan 20, 2005 | 05:51 AM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowSi &raquo;</TD></TR><TR><TD CLASS="quote">Yeah i wish i could do that but i want to keep the AC. i would do the flare right after that, but its a pain in the *** to do the bends, and if there isnt much loss in power by doing it my way, then thats what im gonna do.</TD></TR></TABLE>
I'd just do it as close to the source as possible while staying somehere you feel comfortable.
Yeah, I run a welded sidewinder too, so I love that AC compatibility with 3" DP!
Old Jan 20, 2005 | 07:46 AM
1SlowSi's Avatar
Default Re: (DaX)
how much we talkin about for that? and what downpipe will i need for that. i have a revhard mani and dp.
Old Jan 20, 2005 | 08:23 AM
RyanEJ8's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">Intuition would lead me to believe the sooner you flare the better, but someone with some real knowledge should chime in. I flared directly off the turbine flange.</TD></TR></TABLE>
Your intuition is right.
Old Jan 20, 2005 | 08:26 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (RyanCivic2000)
although i'm not running ac, so my compressor is placed on the drivers side, im going to have it flare directly off of the flange, from 3 (or however big of a pipe i can fit on the flange) to 3.5"
Old Jan 21, 2005 | 02:51 AM
1SlowSi's Avatar
Default Re: (wantboost)
So no one knows a rough estimate how much power i may lose. I guess you could just say... VERY LITTLE, or MODERATE. Would i notice it on the butt dyno?
Old Jan 21, 2005 | 04:18 AM
Finland's Avatar
when it comes to turbo exhaust, delta P makes power, another words you want the highest pressure differential between the turbine inlet and outlet that is possible. Ideally the exhaust tubing diameter should remain the same from turbine outlet to the muffler tip. Since you are dealing with a less than ideal situation, it would take some testing to find out which flare location would provide the highest delta P. I would think that the closer to the turbine outlet, the better; this should give you the most amount of larger diameter piping possible and therefore the least amount of backpressure.
Old Jan 21, 2005 | 07:20 AM
1SlowSi's Avatar
Default Re: (ForceFedDetroit)
i totally agree. Ill have to just make up my mind then. Its just a pain in the *** thats all.
KILLASmoke
15
Jun 5, 2008 05:13 AM
whiteDCfiver
21
Jul 17, 2004 11:46 AM
KenRed
Oct 21, 2003 12:09 PM
NyQuiL
Jul 10, 2003 09:59 PM
Flux
Jun 28, 2001 11:12 AM
