Spool Time: T3 vs. T4
Old Jan 19, 2005 | 09:00 AM
wantboost's Avatar
Who is Mr Robot?
Default Spool Time: T3 vs. T4
I know this queston seems sort of broad and noobish, but here it goes anyway.
Right now,i plan on boosting my stock b16 for a while, then building it with either an 83mm or 84mm bore, with a stock ctroke. I have heard many people say that a motor with that large of a bore spools a t3 turbine section rather quickly. Given my future goals, would i be better off having a t3 turbine section of both the built motor and the stock block, or would a t4 turbine section be better suited.
(sorry if this doesnt make much sense, because i'm running a 103 fever)
Old Jan 19, 2005 | 09:15 AM
SpoolnG2's Avatar
Default Re: Spool Time: T3 vs. T4 (wantboost)
definately get the t3. There are several t3 combos that can producelittle under over 600whp....your much better off with a t3 hot side. such as a precision sc61 or a t3/t67
Old Jan 19, 2005 | 09:49 AM
adseguy's Avatar
Default Re: Spool Time: T3 vs. T4 (SpoolnG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">definately get the t3. There are several t3 combos that can producelittle under over 600whp....your much better off with a t3 hot side. such as a precision sc61 or a t3/t67
couldn't have said it better . The T4 will be laggier and you won't even be pushing the limits of the turbo. A big T3 like the sc61 t3/60-1
Old Jan 19, 2005 | 10:24 AM
TheShodan's Avatar
Moderator
Default Re: Spool Time: T3 vs. T4 (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">
couldn't have said it better . The T4 will be laggier and you won't even be pushing the limits of the turbo. A big T3 like the sc61 t3/60-1</TD></TR></TABLE>
yep.... Couldn't have said it better.
Mugencrxsir1
May 17, 2006 02:56 PM
boostedfe3
May 8, 2005 10:02 AM
redboost10
Oct 24, 2003 09:03 AM
Kp_VtekNiks
Jul 30, 2003 12:26 PM
Andrew 825SM
Jun 20, 2002 12:04 AM
