Surging after injector swap.
Old Jan 19, 2005 | 10:05 AM
1bad-eg's Avatar
Default Surging after injector swap.
What's going on everyone. I have a surging problem after I installed 310 r/c injectors on my car. The engine surges from 1000 to 1500 rpm's. I've checked just about everything as far as vacuum leaks goes, checked the fast idle valve, iac motor, etc. The car doesn't have the cel light on. Still have the stock ecu. Just did the inj. to experiment. Could my problem be running too rich at idle? Thanks for all the help.
Old Jan 19, 2005 | 10:32 AM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: Surging after injector swap. (1bad-eg)
you've got a set of injectors that are of different size then your ecu is calibrated to control.
hmmmm I wonder....
Old Jan 20, 2005 | 08:24 AM
s1ngle's Avatar
Default Re: Surging after injector swap. (stackz)
well, what is your setup? what are you doing for fuel management?
wantboost's Avatar
Who is Mr Robot?
Default Re: Surging after injector swap. (s1ngle)
nothing from the sound of it, just stock ecu with 310 injectors
Old Jan 20, 2005 | 10:14 AM
SOHC_MShue's Avatar
your gonna need something to scale down those injectors.
Old Jan 22, 2005 | 08:25 AM
1bad-eg's Avatar
Default Re: Surging after injector swap. (SOHC_MShue)
Found the problem. Where the injectors go into the intake manifold there are 2 types of grommets. 1 that is soft and 1 that is some type of hard rubber. How come I have 2 different types? Don't know, but anyway, had a huge vacuum leak from the base of the injectors. Installed the right grommets and now no more surging. Thanks
Old Jan 22, 2005 | 08:35 AM
93turbo16's Avatar
yep definitley sounded like a vacuum leak. THe idle wouldn't surge, it would be very rough with the bigger injectors.
Old Jan 24, 2005 | 05:11 AM
1bad-eg's Avatar
Default Re: (93turbo16)
Yeah, you aren't lying about the rough idle.
turboacurab20
Engine Management and Tuning
Mar 16, 2011 08:57 AM
verizon521
Mar 12, 2007 09:21 PM
SFC
Jun 21, 2004 10:32 AM
egturbo
Jul 14, 2003 12:21 AM
Ri5e
Apr 17, 2002 01:12 PM
