SOHC-T owners there is one question unanswered?
I have search for hours and had found no conclusion for what is a good cam for a turbo sohc. I have already used the zex 59300, because thats all the other post said and I didnt like it you can see where the torque just dies what do you guy suggest? whats a good cam,experiences toughts?
16.5psi 250whp 225wtq
Some info on the engine:
D16Z6
bore .20 over wiseco pistons 8.8.1 should be a little bit lower with HG
GE block guard
Scat rods
comp cam, sprocket and springs
ARP headstuds and cosmetics headgasket
RC 550cc and hondata s100b with aem fpr
turbonetics turbo t3/t04e 57 trim 63 a/r
tial 35mm w/g
greddy typy s bov
RH exhaust manifold with drag intercooler
AVC-R boost controller
egt, boost, oil guage
bbk fuel pump
2.5 flared to 3"Dp 3" exhaust
D16Z6
GE block guard
Scat rods
tial 35mm w/g
greddy typy s bov
bbk fuel pump
Re: SOHC-T owners there is one question unanswered? (booscivic)
where was your cam timing set? my zex cam pulls much stronger up top than my stock cam on my y8.
Re: (booscivic)
hey we are running like the same setup except mine is all stock bottom end.. i have a thick headgasket to lower my compression though. i put down 252 and 195 you do have a lot more tq then me though.. how does the came sound?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by booscivic »</TD></TR><TR><TD CLASS="quote">I have search for hours and had found no conclusion for what is a good cam for a turbo sohc. I have already used the zex 59300, because thats all the other post said and I didnt like it you can see where the torque just dies what do you guy suggest? whats a good cam,experiences toughts?
16.5psi 250whp 225wtq</TD></TR></TABLE>
Tuning, tuning, tuning. Play with your cam timing some.
Re: SOHC-T owners there is one question unanswered? (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">where was your cam timing set? my zex cam pulls much stronger up top than my stock cam on my y8.</TD></TR></TABLE>
I agree. Best band for the buck! Sounds like you needed more tuning or fix the cam timing.
I have an almost identical set up and my peak tq was at 7 grand and peak power was at my redline of 7500rpm with the Zex cam. Only difference is I run 9.0:1 compression pistions and the same boost level. Something seems to be off here. Your Tq drops off very fast.
Re: (ELSpool)
I went with a Delta 272 cam, its a high lift n/a cam but **** is it ever amazing
Was much better up top then my Zex cam, I sold my used zex cam for like $150 and bought the new regrind 272 for $130 shipped
Getting a 700rpm idle was a pain though, little lumpy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by booscivic »</TD></TR><TR><TD CLASS="quote">...I didnt like it you can see where the torque just dies...</TD></TR></TABLE>
Fix your boost first, looks like its falling off in the higher rpms. With that turbo it should not be doing that. Your HP takes a **** after like 6k. (thats highly attributing to your torque loss)
What was your A/F from 6000 to 8000?
I'm running a JG 85vt35 cam running straight up it makes great torque to 7500rpm then slopes off slowly. The idle is a little rough though.
The car idles good, just like stock isnt fully tuned, I have new i/c. IM and methanol injection kit to try out. The tuner wanted more time but I was about to be deployed so I couldnt leave my car, trying to figure out the avc-r too. In a month or so I will have new #'s with a lot more boost
Re: (booscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by booscivic »</TD></TR><TR><TD CLASS="quote">Thanks to everybody who helped!!! I found that my boost duty was set to high and the boost was spiking higher THANKS AGAIN FOR EVERYBODYS HELP!!!!
Are you sure you fixed that? Do you have a mechanical guage to confirm?
moomakudafi
02-26-2008 07:08 PM
yusoslo
03-28-2004 09:14 AM
