Boost controller problem. Already searched!!!
Old Jan 21, 2005 | 05:38 AM
boosted-delslow's Avatar
Default Boost controller problem. Already searched!!!
I searched all around and I cant find anything on the exact problem that I am having. I put a turbo xs standard boost controller on my car the other day and I cant get any less than 12 psi. I thought that maybe it was my wastegate because the diaphram had a small hole in it so I got a new diaphram. Last night I installed the new diaphram, put the boost controller back on and I am still having the same problem. I have checked to make sure that the boost controller is not hooked up backwards.
I cant understand why it will hold 7 psi all day long, but as soon as I put the boost controller on it wont do any less than 12-13 psi.
Old Jan 21, 2005 | 06:17 AM
RacerXI's Avatar
Default Re: Boost controller problem. Already searched!!! (boosted-delslow)
Not throwing stones, but is it hooked up correctly as per the instructions? Or tell us how you have it hooked up...
Old Jan 21, 2005 | 07:09 AM
Hyaboosta's Avatar
Default Re: Boost controller problem. Already searched!!! (RacerXI)
explain how exactly you have it hooked up or take some pics and post them up.
Old Jan 21, 2005 | 08:10 AM
Default Re: Boost controller problem. Already searched!!! (Hyaboosta)
I have my vacum line from my wastegate running to the bottom of the boost controller and a vacume line from my vacume manifold running to the side.
http://www.turboxs.com/SBCinstallation.htm
Old Jan 21, 2005 | 10:04 AM
I have checked the vacum lines over and over and they look ok to me.
Old Jan 21, 2005 | 03:03 PM
Nobody??
Old Jan 21, 2005 | 09:16 PM
Problem fixed. I put a differnt wastegate on and everything is working fine.
061000rr
Jun 14, 2011 04:37 AM
swepper
Feb 28, 2009 06:42 PM
ericstambaugh07
Jun 23, 2007 09:04 AM
rudebwoy
Mar 17, 2007 12:53 PM
Meet07
Feb 3, 2004 10:45 PM
