spark plug gap?
Old Jan 20, 2005 | 02:01 PM
Trailz-EX's Avatar
Default spark plug gap?
i just gotta figure out a spark plug gap can any one help... this is whats i gotts:
d16y8 - 9.0:1 - 7.5-8psi i got ngk plugs one step cooler than the stock plugs
stock plugs where 5 these are 4
Old Jan 20, 2005 | 03:29 PM
hondaguyef's Avatar
Default Re: spark plug gap? (Trailz-EX)
.030
Old Jan 20, 2005 | 03:40 PM
turbo95eg6's Avatar
30-35
Old Jan 20, 2005 | 06:00 PM
EJ1 wilcox's Avatar
Default Re: spark plug gap? (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">.030 </TD></TR></TABLE>
That's what mine are at... works like a charm
Old Jan 20, 2005 | 06:02 PM
The Destroyer's Avatar
Default Re: spark plug gap? (EJ1 wilcox)
Out of all the **** ive read on HT, I have never read about gapping plugs for FI applications.
Do you want to make the gap bigger or smaller, and how do you know how much to gap them?
Old Jan 20, 2005 | 06:25 PM
hondaguyef's Avatar
Default Re: spark plug gap? (Vtaaak y0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtaaak y0 &raquo;</TD></TR><TR><TD CLASS="quote">Out of all the **** ive read on HT, I have never read about gapping plugs for FI applications.
Do you want to make the gap bigger or smaller, and how do you know how much to gap them?</TD></TR></TABLE>
You want to make the gap smaller and generally starting at .035(low boost) and moving down from there. What I mean is, you want the widest gap possible w/o misfire. Example: If the engine misfires (it will be rev-limiter style, you'll know) and the gap is at .035 then, tighten it a little to say, .032 and try that. You repeat this process until the engine does not misfire. Different setups will vary from .035-.018(Crazy tight). Cylinder pressure will be the deciding fatcor.
Phil
Old Jan 20, 2005 | 06:44 PM
B O B's Avatar
try 28
Old Jan 20, 2005 | 09:29 PM
jdm-ray's Avatar
From: home of Marciano/Haggler, city of champions, MA
now i got a question. how do you know where your plugs are gapped to the exact number. i.e. .35, .20, .28?
Old Jan 21, 2005 | 03:19 PM
Default Re: (h22boy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22boy &raquo;</TD></TR><TR><TD CLASS="quote">now i got a question. how do you know where your plugs are gapped to the exact number. i.e. .35, .20, .28?</TD></TR></TABLE>
They have a small tool that measures the clearances.
Old Jan 21, 2005 | 03:27 PM
sharkcohen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trailz-EX &raquo;</TD></TR><TR><TD CLASS="quote">i got ngk plugs one step cooler than the stock plugs
stock plugs where 5 these are 4 </TD></TR></TABLE>
4 would be hotter.
BlueShadow's Avatar
Default Re: (Vtaaak y0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vtaaak y0 &raquo;</TD></TR><TR><TD CLASS="quote">They have a small tool that measures the clearances. </TD></TR></TABLE>
I've seen sparkplug gap measuring tools, but he should also be able to use a set of feeler gauges right? when I got a set of plugs from the dealer I used my feeler gauges to check the gap and they were within Honda specs.
Just take several feeler gauges and stack them to check your gap. For example if you wanna make sure they are gapped at 0.28 just get your feeler gauges for 0.10, 0.09, 0.05 and 0.04 add em up and that equals 0.28.
Old Jan 21, 2005 | 03:47 PM
JDM.Accord's Avatar
Default Re: spark plug gap? (sharkcohen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">
4 would be hotter.</TD></TR></TABLE>
That's what I thought. A 6 plug would be one step cooler
Old Jan 22, 2005 | 10:57 AM
Trailz-EX's Avatar
Default Re: spark plug gap? (JDMAccord2nr)
NGK spark plugs go backwards.. they are the only company that does this. my buddy at pep boy got the NGK book out and we look it up, in the front it shows you what each number on the plug stands for.. in most cases 4 would be hotter.. NGK 4 is cooler
Old Jan 22, 2005 | 11:01 AM
YiNYaNg's Avatar
.28
Old Jan 22, 2005 | 02:53 PM
JDM.Accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trailz-EX &raquo;</TD></TR><TR><TD CLASS="quote">NGK spark plugs go backwards.. they are the only company that does this. my buddy at pep boy got the NGK book out and we look it up, in the front it shows you what each number on the plug stands for.. in most cases 4 would be hotter.. NGK 4 is cooler</TD></TR></TABLE>
We've been over this several times. Check this out
https://honda-tech.com/zerothread?id=481272&page=1
Old Jan 22, 2005 | 03:04 PM
sharkcohen's Avatar
Hate to tell you, but you've got it backwards.
Old Jan 22, 2005 | 03:43 PM
thermal's Avatar
NGK 4 is hotter....
Anyway, mine is gapped at 27. Works fine.....
Old Jan 22, 2005 | 05:59 PM
TeamNextGenChris's Avatar
with NGKs,higher number is COLDER.
at 12psi,i have mine gapped at .035 and have no misfire problems.start there and work down,as said above.
Chris
Old Jan 22, 2005 | 09:10 PM
Tony Starks's Avatar
Default Re: spark plug gap? (TeamNextGenChris)
use NGK 1095's gapped at .028
Old Jan 22, 2005 | 09:19 PM
sharkcohen's Avatar
Default Re: spark plug gap? (Tony Starks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony Starks &raquo;</TD></TR><TR><TD CLASS="quote">use NGK 1095's gapped at .028</TD></TR></TABLE>
My favorite plug.
Old Jan 22, 2005 | 11:11 PM
NightRiderS2K's Avatar
In-N-Out Burger
For those non-believers...
Directly from NGK site:
Old Jan 23, 2005 | 06:22 AM
DaX's Avatar
DaX
Loved
Community Favorite
I gap my BKR7E's at .028
Old Jan 23, 2005 | 07:32 AM
mrbsponge's Avatar
brk7e11a here gapped at .023 if i dont do this it misfires
Old Jan 23, 2005 | 07:39 AM
Tchleung's Avatar
I'm running BK47E's at .030 gap... What I noticed is that, they are all pregapped to .030. Anyone else notice this? I went to regrap the new plugs and measured them and they were all perfect. lol
Old Jan 23, 2005 | 12:15 PM
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">I gap my BKR7E's at .028</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">brk7e11a here gapped at .023 if i dont do this it misfires
that's the same plug i'm using,but gapped at .035 at 12psi.how much boost are ya'll running?any ignition mods?that's WAY smaller than what i run,and i have no misfire problems.
Chris
