cannot raise boost above 7psi
Old Jan 18, 2005 | 08:55 PM
FmXRider991's Avatar
Default cannot raise boost above 7psi
I can't raise the boost above 7psi without the motor completely cutting out....it just shuts down. Does this mean my waste gate has a 7psi max spring in it? If so do i just change the spring?
Old Jan 18, 2005 | 09:18 PM
PrettyLude's Avatar
more info on ur setup please
Old Jan 18, 2005 | 11:33 PM
JonnySBeee...'s Avatar
Default Re: cannot raise boost above 7psi (FmXRider991)
motor? car? set-up?
Old Jan 19, 2005 | 12:27 AM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FmXRider991 &raquo;</TD></TR><TR><TD CLASS="quote">I can't raise the boost above 7psi without the motor completely cutting out....it just shuts down. Does this mean my waste gate has a 7psi max spring in it? If so do i just change the spring?</TD></TR></TABLE>
Please dont tell me you just threw a turbo on your car and drove it like that. Im pretty sure your wastegate has a 7psi spring in it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">more info on ur setup please</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonny05 &raquo;</TD></TR><TR><TD CLASS="quote">motor? car? set-up?</TD></TR></TABLE>
Definitely gonna need this as well to try and help you
Old Jan 19, 2005 | 01:36 AM
liam821's Avatar
25 Year Member
Default Re: cannot raise boost above 7psi (TeStUdO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO &raquo;</TD></TR><TR><TD CLASS="quote">
Definitely gonna need this as well to try and help you</TD></TR></TABLE>
Yea it sounds like the car isnt maybe getting any fuel and falling on its face under boost. That would be a bad thing.
liam
Old Jan 19, 2005 | 07:29 AM
PrettyLude's Avatar
Default Re: cannot raise boost above 7psi (liam821)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 &raquo;</TD></TR><TR><TD CLASS="quote">Yea it sounds like the car isnt maybe getting any fuel and falling on its face under boost. That would be a bad thing.
liam</TD></TR></TABLE>
that's what it sounds like, what are you using for fuel management
Old Jan 19, 2005 | 07:46 PM
I have a stock block gsr with a drag kit and hondata. I also have a walboro hi-vol in tank fuel pump and 440 cc injectors. It was fully tuned on a dyno at 6psi, but that was before I had an electronic boost controller. At that time I had a manual one which didnt work properly and would not raise the boost. So i just recently put a profec b spec II in, and tried to raise the boost to about 7.5 psi and the motor just shut down at about 4k rpms on a 4th gear pull.
Old Jan 19, 2005 | 07:59 PM
Default Re: cannot raise boost above 7psi (PrettyLude)
that's what it sounds like, what are you using for fuel management</TD></TR></TABLE>
I have a hondata system which was fully dyno tuned byEvans Tuning, so Im sure that my fuel management is in good shape
Old Jan 19, 2005 | 08:32 PM
garlic jr's Avatar
they set your boost at 6.5 probably. most shops tune for reliability so thats were its most likely set at.
does the car just absolutley die or sorta cut out like its leaning out ? what does your a/f say ? egt ? anything ?
Old Jan 19, 2005 | 09:24 PM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: cannot raise boost above 7psi (garlic jr)
Next time you tune, tune for a max boost setting, that way, you can run any X psi of boost lower than 15psi.
Old Jan 20, 2005 | 04:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garlic jr &raquo;</TD></TR><TR><TD CLASS="quote">they set your boost at 6.5 probably. most shops tune for reliability so thats were its most likely set at.
does the car just absolutley die or sorta cut out like its leaning out ? what does your a/f say ? egt ? anything ? </TD></TR></TABLE>
it completely dies to the point were i slam foward for a split second and then its back to normal.....i only did it like twice cuz it cant be good. The air fuel stays in stoich and my egt is normal
pjr710
May 22, 2009 10:22 AM
juniestyle
Apr 22, 2006 07:12 AM
turbo95eg6
Jun 12, 2005 07:46 PM
5l-eater
Oct 20, 2004 03:26 PM
redboost10
Nov 16, 2003 02:07 PM
