Low/Full Boost .. weird
Old Jan 17, 2005 | 08:26 AM
18psi sohc's Avatar
Default Low/Full Boost .. weird
I have a 1.5L single cam vtec with an sfp turbo manifold, a t3/t4 .48/.60,and a tial 38mm wastegate. The spring is .5bar(7.3 pounds),but the car only hits 5 pounds and the wastegate doesn't open.. I checked for a boost leak and there is none. The engine just about shuts off when you cover the turbo intake. Has anyone else ever had this problem ?? do you have to break in turbo for alot of miles ?
Any help is really apreciated !
Old Jan 17, 2005 | 08:35 AM
GDM Z28's Avatar
Default Re: Low/Full Boost .. weird (18psi sohc)
do u have an exhaust leak? that could cause it. also dont say there isnt a boost leak because u covered the inlet. pump the inlit with air so it builds pressure in the system with the TB closed n see if it holds it or if it leaks out.
Old Jan 17, 2005 | 08:36 AM
GDM Z28's Avatar
Default Re: Low/Full Boost .. weird (civicflnum1)
also when your engine is running maybe your BOV isnt sealing and its letting some boost out?
Old Jan 17, 2005 | 09:08 AM
18psi sohc's Avatar
No the bov isn't letting any boost out. Its a new hks ssqv. And if the engine stalls when you cover the intake on the turbo it cant have a leak because it cant suck air from anywhere.
Old Jan 17, 2005 | 09:09 AM
18psi sohc's Avatar
And no it doesn't have an exhuast leak.
Old Jan 17, 2005 | 09:12 AM
EJ1 wilcox's Avatar
What kind of filter do you have on the inlet?
I had a few layers of thick screen over mine and it wouldn't allow enough air into the turbo to reach full boost... the symptoms were exactly what you described...
I would only see like 4 or 5 pounds of boost, which wasn't enough to open up the wastegate...
I replaced the screen with a real air filter and the problem was solved!
Old Jan 17, 2005 | 11:38 AM
18psi sohc's Avatar
No filter.. That's gonna drive me crazy !
TravisBiggie
Mar 1, 2013 05:59 PM
jacob4lester
Feb 7, 2010 09:51 AM
richboi
Apr 15, 2007 07:46 PM
MiMiK
Dec 10, 2005 06:21 PM
mattcalica
Apr 20, 2004 05:15 PM
