exhaust size and tuning
Old Jan 20, 2005 | 10:16 AM
igo4bmx's Avatar
Default exhaust size and tuning
Im am going to get my car tuned from jeff in about a month... however i will have a 3 inch downppipe going into a 60mm apexi cat back exhaust (and test pipe)
would it be best to tune the car with a full 3 inch now, or can i wait till later to buy one after the tune?
Old Jan 20, 2005 | 10:28 AM
94lsboost's Avatar
Default Re: exhaust size and tuning (igo4bmx)
It would be best to tune it with the setup that you plan to run. Although it may not change enough to make it run bad, ideally you want to tune on the setup you are going to run so it is as close to perfect as possible.
Old Jan 20, 2005 | 10:29 AM
93turbo16's Avatar
I would say have everything you want to have on the car done, before you get it tuned.
Old Jan 20, 2005 | 10:50 AM
igo4bmx's Avatar
damn.... more money to spend
Old Jan 20, 2005 | 11:38 AM
93turbo16's Avatar
thats how it always goes
Old Jan 20, 2005 | 11:58 AM
StolenTeg's Avatar
Default Re: (93turbo16)
It will lean out a little bit if you step up to a bigger downpipe/exhaust system, the boost might increase a little too due to the gas can now exit much quicker...
rudebwoy
Oct 27, 2007 05:33 AM
pr0honda
25
Mar 5, 2007 05:31 PM
B16Civic93
May 31, 2005 07:04 PM
goose21
Jun 26, 2004 12:44 PM
Rory Breaker
May 1, 2004 10:24 AM
