Uninstalled turbo..now very bad idle
So I just finished putting my car back to stock..I start her up and she hesitates then kicks over..
But the idle is very low (300-400), jumping up and down..
Ive checked the vac lines and theyre all good..
Any help would be very much appreciated.
Re: Uninstalled turbo..now very bad idle (Accurate GS-R)
Yeah, I had bad idle problems and thought it was a vacuum leak. I checked all of my connections a dozen times before I finally found an almost invisible split in one of the lines.
Re: Uninstalled turbo..now very bad idle (beepy)
Take out the missing link and run the map the regular way also make sure you put back regular spark plugs just in case you were running colder plug's, also check your fuel press, timing, vac line etc....
Re: Uninstalled turbo..now very bad idle (JdmEKCivic)
^^ also a custom chiped ecu for turbo won't run good with a all motor setup, different map, look into that, might be why the idel is fucked
Key Enzyme
Engine Management and Tuning
03-29-2013 08:24 AM
ProjectEvilEj2
12
06-16-2012 09:05 AM
