how long has your race engine lasted.......
Old Jan 20, 2005 | 01:15 PM
b00stedbyFastrax's Avatar
Default how long has your race engine lasted.......
if you ran your car real hard for a whole season. i am talking about lots of dyno time ( maybe 50-75 pulls), burnout after burnout, staging with the 2 step @ 7000-8000 rpm and shifting @9000, on a 500 WHP engine.
Well mine has went about 1-1/2 yrs with ~ 600whp. now i am burning a lot of oil. car stills pull hard.
Old Jan 20, 2005 | 01:25 PM
m R g S r's Avatar
Default Re: how long has your race engine lasted....... (b00stedbyFastrax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00stedbyFastrax &raquo;</TD></TR><TR><TD CLASS="quote">if you ran your car real hard for a whole season. i am talking about lots of dyno time ( maybe 50-75 pulls), burnout after burnout, staging with the 2 step @ 7000-8000 rpm and shifting @9000, on a 500 WHP engine.
Well mine has went about 1-1/2 yrs with ~ 600whp. now i am burning a lot of oil. car stills pull hard.</TD></TR></TABLE>
Are you getting blowby? Or is it in the head? Spun bearing? Could just be oil rings if the car stillpulls hard and compression is up. . .
Old Jan 20, 2005 | 01:51 PM
Stewie's Avatar
Default Re: how long has your race engine lasted....... (m R g S r)
I would consider that more than successful. SOme one knows how to build and tune a motor.
Old Jan 20, 2005 | 01:58 PM
mattssi's Avatar
sounds like if it blew tomorrow you should be satisfyed.
Old Jan 20, 2005 | 02:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">
Are you getting blowby? Or is it in the head? Spun bearing? Could just be oil rings if the car stillpulls hard and compression is up. . . </TD></TR></TABLE>
yeah, i think is oil rings. gonna re-ring the block soon.
Old Jan 20, 2005 | 02:07 PM
Trailz-EX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi &raquo;</TD></TR><TR><TD CLASS="quote">sounds like if it blew tomorrow you should be satisfyed. </TD></TR></TABLE>
ha ha i ran with about half the horsies and didnt beat on it and it lasted an amayzing two weeks! we should all be so lucky.... if you ran it all season like that it couldnt hurt to "recondition the motor" before it goes boom! and your stuck looking for a new block and rods and pistons and probably everything else under the hood
Default Re: (mattssi)
yeah i am sort of satisfied. i haven't hit 10's yet. best time was a 11.6 @ 133 with a 1.94 60ft. it is probaly oil rings. a lot of people always ask whether i think the engine will let go when i line up to race. i tell them no, the car just feels fine on every run.
Old Jan 20, 2005 | 02:59 PM
NVturbo's Avatar
O.G. triple O.G.
My old re-used main bearings didn't last too long. Messed up two oil pumps (LS and ITR) and experiencing bad blowby's. I am in the process of rebuilding my motor .... with new bearings (ACL main, rods and thrust), new WISECO rings/seals, new OEM-Honda gaskets, etc. and a freshly balanced/polished crank. Hopefully, this time all things will hold up because DOWNTIME sucks!!! OH yeah, word of advice...stay away from the OEM-Honda CTR "race" crank pulley!
Old Jan 20, 2005 | 03:12 PM
Default Re: how long has your race engine lasted....... (NVturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NVturbo &raquo;</TD></TR><TR><TD CLASS="quote">My old re-used main bearings didn't last too long. Messed up two oil pumps (LS and ITR) and experiencing bad blowby's. I am in the process of rebuilding my motor .... with new bearings (ACL main, rods and thrust), new WISECO rings/seals, new OEM-Honda gaskets, etc. and a freshly balanced/polished crank. Hopefully, this time all things will hold up because DOWNTIME sucks!!! OH yeah, word of advice...stay away from the OEM-Honda CTR "race" crank pulley! </TD></TR></TABLE>
i used new oem bearing all around. new oil pump with pro drive gears on the build. now is just to tear it down and inspect everything. good luck on your build.
Old Jan 20, 2005 | 03:18 PM
NVturbo's Avatar
O.G. triple O.G.
i used new oem bearing all around. new oil pump with pro drive gears on the build. now is just to tear it down and inspect everything. good luck on your build.</TD></TR></TABLE>Thanks bro...I'm just waiting for the crank to be balanced and polished from a local machine shop. I would'nt mind using OEM Honda bearings..but for the money, I opted for the ACL's. Plus, I need to refab a new downpipe since I relocated the compressor onto the driver side.
got-vtec?
Sep 29, 2011 06:24 PM
turboteg90
Feb 11, 2008 08:07 PM
qwk db8
Dec 31, 2007 03:56 AM
gelok
Jun 10, 2004 09:22 AM
Typel2
Aug 11, 2002 07:36 PM
