Oil return question
Old Jan 19, 2005 | 06:02 PM
fandango's Avatar
Default Oil return question
i was wondering if anyone had any suggestions or pics on how and where i should put my oil return on my oil pan. i dont know how low or how far to one side or what. and would my crank spinning have any effect on the oil being held back in the dump tube? any suggestions would really help. thanks.
Old Jan 19, 2005 | 06:05 PM
DaX's Avatar
DaX
Loved
Community Favorite
You want your oil return bung to be:
*as high as possible in the pan
*between two of the holes in the pan so you can still bolt the pan to the block
*most people prefer the bung in the deep part of the pan
You shouldn't have any oil in your dump tube, ever. For your car's sake I hope you mean oil return.
Modified by DaX at 9:52 PM 1/23/2005
Old Jan 19, 2005 | 06:09 PM
fandango's Avatar
Default Re: (DaX)
thanks for the pic.
Old Jan 19, 2005 | 07:35 PM
BoostedJeff's Avatar
Default Re: (fandango)
that is the same style oil return i have, and leaking problems from the fitting gon the pan?
Old Jan 19, 2005 | 08:14 PM
1Bar GSR's Avatar
Default Re: (BoostedJeff)
On my oil pan we braze welded the fitting to the oil pan and its held great might not look gorgeous but serves the purpose!
BTW: Mines almost on the exact same spot Dax's is!
Old Jan 20, 2005 | 05:16 AM
DaX's Avatar
DaX
Loved
Community Favorite
I also brazed mine to the pan with a coat hanger, then repainted the area. The brazing looks smoother than a weld. I have no leak issues. The oil residue you may see in the picture is from an improperly installed oil pan gasket that was fixed.
Old Jan 20, 2005 | 05:21 AM
nonvtecD's Avatar
Default Re: (DaX)
Here's mine, JBweld is your friend
Old Jan 20, 2005 | 07:58 AM
mattEG's Avatar
I drilled a hole and used a sandwich nut with a gasket in between.. So far it hasn't leaked and i've put about 8000km on it.
Old Jan 20, 2005 | 08:02 AM
Bailhatch's Avatar
Default Re: (D15B7turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D15B7turbo &raquo;</TD></TR><TR><TD CLASS="quote">Here's mine, JBweld is NOT your friend
That was a close one, no need to thank me.
wantboost's Avatar
Who is Mr Robot?
Default Re: (Bailhatch)
^lmfao
Old Jan 20, 2005 | 08:13 AM
RyanEJ8's Avatar
JBWeld is your friend if you like leaks.
Old Jan 20, 2005 | 08:15 AM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D15B7turbo &raquo;</TD></TR><TR><TD CLASS="quote">Here's mine, JBweld is your friend
I didn't use JB weld, but RTV can be a friend too. HAHA
Old Jan 20, 2005 | 08:47 AM
tegstyles's Avatar
Default Re: (DaX)
Any links on where I can get a similar setup? I'm having some bad oil return horror stories.
Old Jan 20, 2005 | 09:05 AM
DaX's Avatar
DaX
Loved
Community Favorite
I got all my turbo lines from Flamenco-T here on H-T. He works for http://www.fast-turbo.com
Old Jan 20, 2005 | 11:38 AM
Targa4Life's Avatar
Default Re: (DaX)
What size steel braided line did you use and with what fittings? Im in the process of getting this stuff to do it the right way this time.
Old Jan 20, 2005 | 12:10 PM
nonvtecD's Avatar
Say what you will about JB, but I got his back
Old Jan 20, 2005 | 12:13 PM
93turbo16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D15B7turbo &raquo;</TD></TR><TR><TD CLASS="quote">Say what you will about JB, but I got his back</TD></TR></TABLE>
Old Jan 20, 2005 | 12:18 PM
ZEXGS-R's Avatar
Default Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">I got all my turbo lines from Flamenco-T here on H-T. He works for http://www.fast-turbo.com</TD></TR></TABLE>
Stan's oil line kit is great. I haven't had any problems with mine.
Old Jan 20, 2005 | 12:40 PM
sporkcrx's Avatar
Default Re: (DaX)
haha, I did this the first time I put on my oil return. I didn't pay any attention to the bolt holes, but to putting it behind a main so the crank wind wouldn't restrict it (not sure if this is a myth or fact) but it was ok, I just had to start threading the bolt while putting the pan on, and use a wrench.
Old Jan 20, 2005 | 01:38 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (Targa4Life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa4Life &raquo;</TD></TR><TR><TD CLASS="quote">What size steel braided line did you use and with what fittings? Im in the process of getting this stuff to do it the right way this time.</TD></TR></TABLE>
The fast-turbo kit uses a -10AN oil return line with a 45* fitting off the turbo to a straight fitting on the line. There is a 45* swivel fitting on the other end of the line which is connected to the bung welded to my oil pan.
The feed is a -3AN line, with appropriate fittings at both ends.
Old Jan 20, 2005 | 06:20 PM
fandango's Avatar
cool.. im getting lots of info. thanks guys
delslow45
Apr 3, 2011 07:14 PM
K20A2 5 lug EG
Aug 6, 2008 11:50 AM
Stewie
Welding / Fabrication
Nov 9, 2005 08:38 AM
