unstable boost ?
Old Jan 16, 2005 | 06:20 PM
jspeedy's Avatar
Default unstable boost ?
I recently finished the turbo set up on my car and I'm getting periodic unstable boost. I'm running 10-12lbs controlled through a greddy profect b2 and the waste gate spring is 7lbs. What happens is boost goes up to 7lbs progresses to 10-12 then falls back to 7 then back to 12. I've got the peddle to the floor but the waste gate sounds like I'm coming on and off the gas. This is a used kit so I was thinking that the wg spring may need to be replaced.
Any ideas.
H22a1 GE mid Sleeves
JE 9:1 pistons
IB light Rods
Fmax kit w/t3/t4e 60 trim
Tial 35mm wg 7lbs spring
Msd A6
720 cc injectors
AEM EMS
Greddy profect b
Other odds and ends.
13.8 @ 102 @ 7lbs
Old Jan 16, 2005 | 11:38 PM
ForcedEk9's Avatar
Default Re: unstable boost ? (jspeedy)
it might be the samoflange in the mega plenum. Check and see if you've got enough fluid in your tires and replace the anti-spasmatic switch while your at it.
Old Jan 17, 2005 | 06:42 AM
jspeedy's Avatar
Default Re: unstable boost ? (ForcedEk9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForcedEk9 &raquo;</TD></TR><TR><TD CLASS="quote">it might be the samoflange in the mega plenum. Check and see if you've got enough fluid in your tires and replace the anti-spasmatic switch while your at it.</TD></TR></TABLE>
Thanks ***!
flangemastermike
Jul 1, 2008 11:06 AM
Kelly.
Jul 22, 2005 06:05 PM
turbo95eg6
Jun 12, 2005 07:46 PM
mildly.interesting
Jan 1, 2005 05:36 PM
saso
Jul 1, 2003 08:21 AM
