arp head studs stock in block
Old Jan 21, 2005 | 08:31 AM
B18EG6's Avatar
Default arp head studs stock in block
my arp head studs are stuck in my block. I tried double nutting them, **** even triple nutting them. Little success, i got one of them out.
Why are they stuck? I tightened them down to 12 ft-lbs when I installed them
any help?
Old Jan 21, 2005 | 08:37 AM
crispydee's Avatar
Default Re: arp head studs stock in block (B18EG6)
This might be why its says in the instructions to only do them finger tight. Did in mine anyway. Get a pair of big grips on the middle part of the stud. ake sure to clean them up well before you reinstall them.
Old Jan 21, 2005 | 09:13 AM
beepy's Avatar
Default Re: arp head studs stock in block (crispydee)
Tap lightly down on the ends with a wooden or rubber mallet. Usually does the trick for me.
Old Jan 21, 2005 | 09:28 AM
B18EG6's Avatar
Default Re: arp head studs stock in block (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">Tap lightly down on the ends with a wooden or rubber mallet. Usually does the trick for me.</TD></TR></TABLE>
like.. tap transverse to the stud? or tap it on the top into the block?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crispydee &raquo;</TD></TR><TR><TD CLASS="quote">This might be why its says in the instructions to only do them finger tight. Did in mine anyway. Get a pair of big grips on the middle part of the stud. ake sure to clean them up well before you reinstall them. </TD></TR></TABLE>
eh - would this f*ck up the middles of the studs?
Old Jan 21, 2005 | 11:06 AM
crispydee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 &raquo;</TD></TR><TR><TD CLASS="quote">
eh - would this f*ck up the middles of the studs?</TD></TR></TABLE>
Not if your care full put some thin rubber around the shaft and grip on that. Try tapping directly on the top like already said as you put pressure on the grips.
Old Jan 22, 2005 | 09:28 AM
B18EG6's Avatar
Not if your care full put some thin rubber around the shaft and grip on that. Try tapping directly on the top like already said as you put pressure on the grips. </TD></TR></TABLE>
thanks, ill try that as soon as i can find my vice grips
anymore advice?
Old Jan 22, 2005 | 10:15 AM
W O T's Avatar
12 ft/lbs is basically hand tight
Are you sure you didnt cross thread every one lol?
If there is still any of the center unthreaded section showing that easily how you get it out, just wrap the stud in a thin cloth so you dont "teeth" it all up
wernhersey
Mar 25, 2008 11:49 AM
skiracer8148
17
Apr 1, 2007 09:17 PM
GRTechnologies
Oct 11, 2004 06:51 AM
CTR-CRX
Mar 14, 2004 07:05 PM
xjohnx
Sep 13, 2001 04:49 PM
