wastegate spring installation
Old Jan 20, 2005 | 05:34 PM
integratuner94's Avatar
Default wastegate spring installation
Does anyone have a link, or a decent explaination of how to change a wastegate spring. right now i have a 9psi spring and i want to go to something smaller, maybe a 5 or 7, but ive never opened up a wastegate before. I have a Tial 38mm.
...on a side note the reason im doing this is because im getting boost creep up to about 10-11psi. im hoping with the smaller spring, even with creep maybe it wont go so high. then if it does hold at 5-7psi, i could use a boost controller to turn it up some from there... basically, im looking for a relatively cheap fix untill i can get some money for a motor build, and a better manifold.
Old Jan 20, 2005 | 05:51 PM
JdmEKCivic's Avatar
Default Re: wastegate spring installation (integratuner94)
Just unscrew the wg but be careful on the last bolt cause the spring will fly. once you get it open just put the new one on and close
SilverWarrior
Mar 30, 2008 03:32 PM
_Cyclone_
May 4, 2005 02:32 PM
B00ST2nR
Nov 3, 2004 11:39 AM
W.Zero
Oct 28, 2003 11:42 PM
