Bad piston ring or bad valve, need help!
Old Jan 20, 2005 | 05:08 PM
sway892's Avatar
Default Bad piston ring or bad valve, need help!
A couple of months ago my car went down, I thought it was that a spark plug wire that came off. I stopped and checked and everything was connected, I damned near POOPED my pants.
After I left work I checked the compression Cyl. 1 - 135
Cyl. 2 - 130
Cyl. 3 - 130
Cyl. 4 - goose egg
My setup:
B18C1
DRAG 3 kit (7psi)
stock internals
My question are:
What else can I do to pinpoint the problem?
Why do I have ZERO compression? (even with bad rings, I would still get somekind pressure)
I'm all ears
Old Jan 20, 2005 | 05:59 PM
The Destroyer's Avatar
Default Re: Bad piston ring or bad valve, need help! (sway892)
Pour a very little amount of oil in each cylinder and see if the compression goes up than its the rings.
The oil will form a temporary seal.
Old Jan 21, 2005 | 01:24 AM
sway892's Avatar
Default Re: Bad piston ring or bad valve, need help! (Vtaaak y0)
Is there anyway that I check the valves?
Old Jan 21, 2005 | 07:54 AM
Well if the compression goes up, you can pretty much assume its the valves.
Old Jan 21, 2005 | 08:31 AM
slrh22hatch's Avatar
If you have 0 compression it is most likely that you are missing a big chunk out of a valve or valves.
H22 CB
Oct 30, 2015 05:23 PM
jc2801
27
Aug 25, 2015 08:22 PM
lilshady6796
Jun 20, 2009 07:12 PM
lilo_goki
Feb 18, 2009 01:56 AM
v8killaz
Feb 17, 2008 04:20 PM
