should i run gsr cams in a b16a
99ex b16a (firstgen)w/ls tranny with drag kit.......should i buy gsr intake exhaust cams for it? and what distributor do i need?
Re: should i run gsr cams in a b16a (Ryceboi318)
You need a 99-00 SI distributor. As for the cams, I have seen excellent power made on both. I personally would make the switch though.
Phil
Phil
GSR are a nice fairly cheap/easy upgrade from b16 cams. ITR's can make more power, but they're a premium compared to the sub $100 of the gsr. I'm not aware of needing to swap distributors though.
Re: should i run gsr cams in a b16a (respectblades)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by respectblades »</TD></TR><TR><TD CLASS="quote">i think what he's saying is that for boost gsr's are better than b16a's cams</TD></TR></TABLE>
yupppp
yupppp
Re: should i run gsr cams in a b16a (m R g S r)
for GSR cams don't you only need one because the b16 intake cam is the same as the GSR exhaust cam? or something like that (may be the reverse)?
can someone clarify or confirm what I'm saying...?
I know what I'm talking about, it's just that I don't know what the hell I'm talking about
CANTFAZZDISCHIT
08-18-2003 11:47 AM
