Limiting boost
Old Jan 20, 2005 | 06:01 PM
microsoft_sux's Avatar
Default Limiting boost
Ok, say I'm set up so I can run 15psi. But say I wanna be able to just drive at 5 or 6 and then be able to switch up to 15 when I need it, is that possible? I know that you can use a wastegate to set the max amount of boost but is there a way to switch it while driving? Someone please explain this to me, im trying to do my research on this before I do it to my GSR.
Old Jan 20, 2005 | 06:04 PM
Civicman86's Avatar
Default Re: Limiting boost (microsoft_sux)
Get a boost controller. If your wanting to switch setting in car get a Electronic one.
Old Jan 20, 2005 | 06:10 PM
so an electronic boost controller will do that for me. Sweet, thanks for the info.
Old Jan 20, 2005 | 06:11 PM
MooreBoost's Avatar
Default Re: (microsoft_sux)
Buy a wastegate spring for the lowest psi you wish to run, then just run a dual stage, or electronic boost controller, and set the high boost to whatever psi you wish to run at that stage.
Old Jan 20, 2005 | 06:48 PM
LSVtechnologytur...'s Avatar
Default Re: (MooreBoost)
to do that, do you need two preset tunes?
Old Jan 20, 2005 | 07:02 PM
DC2 BOOST's Avatar
Default Re: (vtec'n)
Get a turbo XS dual stage boost controller just a flick of a switch U could switch into a different boost level and its easier to use but without the Advantage of a electronic boost controller
Old Jan 20, 2005 | 07:28 PM
beepy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec’n &raquo;</TD></TR><TR><TD CLASS="quote">to do that, do you need two preset tunes?</TD></TR></TABLE>
Nope. Speed density system, so you just won't use the entire map in the low boost setting.
Old Jan 20, 2005 | 08:09 PM
Dunc's Avatar
BCICAN
Default Re: (beepy)
why not just limit the amount of boost with your foot and the gas pedal??? You'll only be at 15psi for like .1% of the time you are driving a daily driver.
Old Jan 21, 2005 | 04:51 AM
I have a lead foot and wanna save gas without having to conciously limit myself on the throttle.
Old Jan 21, 2005 | 09:15 PM
Dunc's Avatar
BCICAN
So do you floor it while accelerating everytime to redline?? If not, then you'll only be at full boost like less then 1% of the driving time. That's all I was saying by limiting boost with the gas pedal.
jv88_dc2
Jun 12, 2012 03:49 AM
85
Sep 1, 2010 12:59 PM
blwn95civic
Apr 5, 2007 09:41 AM
RobbieG35
Jul 4, 2006 04:42 AM
vtec.dc2
Jul 16, 2003 06:39 PM
