About to hit the dyno:built h22... numbers???
Whats up guys im new here and just wanted to share my setup, and see waht you guys thought....
89mm golden eagle sleeved block
custom 89mm arias 9.2:1 CR pistons
Eagle H Beams
OEM BEARINGS
polished stock crank, rotating assembly blueprinted and balanced
ARP head studs
stock head....
revhard stg 2 kit w/ t3/To4e .50 AR 2.5 in dp, 3 inch custom exhaust with apexi muffler
str 70mm throttle body
MSD blaster coil
RC 550s w venom hi flow rail and AEM FPR...
hondata s200 with boost...
i was just wondering what i should expect from this setup.. a freind with a similar setup netted 300 whp at 14 psi, on a very conservative tune, im shooting for high 300's, maybe 380 on 17-19 PSI
what are your thoughts thanks in advance !!
Eagle H Beams
OEM BEARINGS
ARP head studs
stock head....
MSD blaster coil
