help:: whats this mean????????? pics inside
Old Jan 18, 2005 | 07:07 PM
sykotik sol's Avatar
Default help:: whats this mean????????? pics inside
ok, today i just got my new block in and everything hooked up..after startup white smoke was everywhere(filled my garage up) then i noticed a water leak so i shut it down, then i noticed this!
could it be from when i burnt up the rings in my old block??could there be oil in the turbo?? and if i let the car run will it burn out?heres a pic to show you what it looks like..more pics-info ::scroll down
Modified by sykotik sol at 3:09 AM 1/20/2005
Old Jan 18, 2005 | 07:24 PM
shadow103rd's Avatar
Default Re: help:: whats this mean????????? pics inside (sykotik sol)
Seals are most likely gone....rebuild needed.
Jon
EDIT: Take it outside and let it run for awhile....If the smoke doesnt go away, then seals are gone.
Old Jan 18, 2005 | 07:34 PM
Default Re: help:: whats this mean????????? pics inside (shadow103rd)
yea, im going to tomorrow..ive got a few other things i have to fix and hopefully that oil will burn up...had no problems w/ it before i took it off
Old Jan 18, 2005 | 08:03 PM
G
sh!t happens.
DAMN.... seals....
Old Jan 19, 2005 | 02:51 AM
ttt
Old Jan 19, 2005 | 05:54 AM
wantboost's Avatar
Who is Mr Robot?
seals are gone, needs a rebuild
Old Jan 19, 2005 | 06:55 AM
SpoolnG2's Avatar
Default Re: help:: whats this mean????????? pics inside (wantboost)
you didnt believe me huh?
Old Jan 19, 2005 | 07:01 AM
92jdmhatch's Avatar
Default Re: help:: whats this mean????????? pics inside (SpoolnG2)
seals r gone...my friend had same problem
Old Jan 19, 2005 | 08:59 AM
richeybrooks's Avatar
Default Re: help:: whats this mean????????? pics inside (92jdmhatch)
i would not recommand taking it out and running it! just take the Charge pipe off and if there is oil BINGO.
Old Jan 19, 2005 | 09:01 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: help:: whats this mean????????? pics inside (richeybrooks)
not always true, the seals can go on the turbine side, but be fine on the compressor side.
Old Jan 19, 2005 | 12:53 PM
spoolng2, i posted this before i talked to you....but sorta looks liek everyone thinks its the seals...f*ck!
anymore thoughts or comments from people????and if i decide to let it idle and burn out will it hurt anything...this is a brand new 0miles built/sleeved block
i dont want to risk screwing it up cuzz it cost alot'o'loot
Old Jan 19, 2005 | 01:52 PM
dome's Avatar
do not start, when seal are bad. you can lose alot of oil. and it wont burn out right away it takes a while. you could starve the bearing from to much oil lost. trust me i have seen it. and to rebuild i would not suggest just get a new one
Old Jan 19, 2005 | 02:01 PM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: help:: whats this mean????????? pics inside (dome)
yeah, rebuilding a turbo without a proper rebalance at a turboshop is risky to say the least.
sell it as a rebuildable core on ebay and go get you another turbo.
you still have a stock exhaust setup around somewhere?? toss that on there and crank it up with the turbo feed line plugged up and see if the smoke clears (since there's probably oil still in the exhaust that needs to burn out....)
Old Jan 19, 2005 | 02:18 PM
Default Re: help:: whats this mean????????? pics inside (stackz)
well if the seals were bad would the car run weird or would it just leak oil?? also this is an almost new turbo, just burnt a ring...so im not really trying to get a new one...costs way too much, id rather pay a 2-300 to rebuild....
Old Jan 19, 2005 | 02:21 PM
wantboost's Avatar
Who is Mr Robot?
the car shouldnt run weird, it shuold just smoke alot. If the car does run weird, then check and see if the seals on the compressor side are shot as well. Just pull a charge pipe off and check for oil residue. The odd running confition could be caused by the motor ingesting oil
EDIT: Cheapturbo.com (now Phoenixturbo) charges 250 for the average rebuild, including rebalancing
Old Jan 19, 2005 | 02:47 PM
do you think this dent in the oil pan is effecting it? i couldnt get to where the dent is to beat it out...and heres another pic of where its coming out of wastegate..why would oil be coming from here if it was seals? maybe head f'd up..?not turbo??
Old Jan 19, 2005 | 03:32 PM
Default Re: (sykotik sol)
there wasnt much oil in charge pipes..i think it might be my headbut still unsure..
Modified by sykotik sol at 2:09 AM 1/20/2005
Modified by sykotik sol at 2:19 AM 1/20/2005
Old Jan 19, 2005 | 04:54 PM
ttt
Old Jan 19, 2005 | 04:59 PM
wantboost's Avatar
Who is Mr Robot?
could be the valve seals in the head. i'd put my money on that
Old Jan 19, 2005 | 05:15 PM
tepid1's Avatar
What size oil line are you running to the turbo
Old Jan 19, 2005 | 05:21 PM
Default Re: (tepid1)
hmm..unsure of exact size..maybe 1/4 or 3/8"..this turbo setup ran fine before, so the line wouldnt matter just because of a new block
Old Jan 19, 2005 | 05:44 PM
nsxmatt's Avatar
Looks like you have oil coming out of the exhaust ports, that wouldn't be a turbo seal. Like was said before could be the valve seals or the rings. Depends on what was done to the engine.
Old Jan 19, 2005 | 05:57 PM
Default Re: (nsxmatt)
well this head was on 2 other block that burnt pistons/rings, thats what leaves me to believe it might be the head....
the block is brand new 0 miles, built by inline pro..so theres nothing the matter w/ block its either head or turbo or some other source of oil...
since its an ls/vtec setup, do you think oil could be coming in somewhere else? but i tapped in where all ls/vtec oil lines are put and turbo oil feed is coming from golden eagle oil filter adaptor
Old Jan 19, 2005 | 06:04 PM
nsxmatt's Avatar
I would "guess" it's the valve seals. If you have a compression fitting for the spark plug hole it's not hard to change them out with the head on the car but with that much money in the block I would take the head off and have a machine shop go over it just to be sure.
Old Jan 20, 2005 | 12:21 PM
ttt
