Emissions testing?
Old Jan 20, 2005 | 04:25 PM
ginoboy1978's Avatar
Default Emissions testing?
Garret t3/t04e turbo 47 trim with 50 a/r
Stainless steel turbo manifold
38mm waste gate
Greddy type s blow off valve
Chipped OBD1 P28 ECU
OBD2b to OBD1 jumper conversion harness
Precision 440cc fuel injectors w/ clips
Street imports Bar and Plate front mount intercooler..the core is
18x9x2
All charge pipes
all vacuum and oil hoses
All gauges (5 total) with tripod and dual bezel
I drive a 1999 Honda Civic. My engine is a D16Y8. I will be tuning(using Uberdata/Hondata/Crome etc).
I just want to know if you think i will pass emission testing. Please advise, thanks.
DAN
Old Jan 20, 2005 | 04:50 PM
mycron's Avatar
Default Re: Emissions testing? (ginoboy1978)
hehe just asked this question
https://honda-tech.com/zerothread?id=1121982
but basically no it wont. Unless all you have is a sniffer test. But with us OBDII guys they usually plug into our ecu to check for codes and since you'll be using an OBDI ecu you will fail =[
Old Jan 20, 2005 | 06:58 PM
Default Re: Emissions testing? (mycron)
In Canada i don't think they plug into your ecu. I think they just do a sniffer test and thats it. If that is the case do you think i can pass? Please advise, thanks.
DAN
Old Jan 20, 2005 | 07:10 PM
It's confirmed.....in Ontario Canada all they do is a sniffer test. See below(i cut and pasted it from a website)
"An emissions inspector will drive your car or lightduty truck onto a dynamometer. This machine is like a treadmill that allows the vehicle to be “driven” on one spot. A probe is placed in the tailpipe of your vehicle. The probe is connected to a gas analyzer and computer, which can measure the concentration of nitrogen oxides (NOx), hydrocarbons (HC), which are volatile organic compounds or VOCs, and carbon monoxide (CO). The vehicle is warmed up to normal operating temperature, and emissions readings are taken while the vehicle is driven on the dynamometer, and then while idling at the end of the test. The test results are compared by a computer to emissions standards for the vehicle and its model year. For example, if you drive a 1995 model car, it will be tested against 1995 emissions standards for that vehicle. Included in the test standards is an allowance for vehicle age and deterioration.
There you go.......that how we test in Ontario Canada. So do you think my car can pass if it's tuned really good?
DAN
'00DC2
Northern California
Oct 19, 2010 06:42 PM
TypeSLO
Jul 31, 2006 04:29 AM
bonylad
Sep 26, 2005 03:53 AM
99skunkedSi
Oct 24, 2004 10:30 PM
prelude9999
Sep 29, 2004 09:07 AM
