what are the limits of pump gas and boost?
Old Jan 19, 2005 | 05:48 PM
rextec's Avatar
Default what are the limits of pump gas and boost?
like the topic says. is it hp related? amount of psi? cylinder pressure? i want to know because i would like to see how much power i can get out of my setup on 91 octane without blowing it up .
Old Jan 19, 2005 | 06:28 PM
b16sedan's Avatar
Default Re: what are the limits of pump gas and boost? (rextec)
On a 9:1 motor, 400 WHP is very attainable on 91 octane. You can't even hook up that much on the street, so why try for more.
Old Jan 19, 2005 | 07:38 PM
BoostedJeff's Avatar
ran 20 psi at an estimated 425-450whp on 93 pump.
motor is sleeved, 9:1 b16
EDIT: this was on a street tune
Old Jan 19, 2005 | 07:48 PM
buck02's Avatar
Default Re: what are the limits of pump gas and boost? (BoostedJeff)
i made 519 on pump 91 octane
street tune on 13psi
Old Jan 19, 2005 | 07:54 PM
Default Re: what are the limits of pump gas and boost? (buck02)
what turbo, displacement?
Old Jan 19, 2005 | 08:53 PM
buck02's Avatar
here is the linkl for ya
https://honda-tech.com/zerothread?id=1069470
84mm b18c1
endyne head
gt40s turbo
Old Jan 19, 2005 | 09:37 PM
mchuang's Avatar
made 343 on 9psi stock bore stock stroke gsr
Old Jan 19, 2005 | 10:14 PM
rextec's Avatar
beautiful!! keep em coming! what limits power then?
Old Jan 19, 2005 | 10:25 PM
Quad-Damag's Avatar
Default Re: (rextec)
anyone ever make 400whp on like 10.0.1 comp on pump 91 CA suckssss
Old Jan 19, 2005 | 10:32 PM
The Phil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rextec &raquo;</TD></TR><TR><TD CLASS="quote">beautiful!! keep em coming! what limits power then?</TD></TR></TABLE>
ur motor blowing up?
Old Jan 19, 2005 | 10:57 PM
Touge Tuning's Avatar
id also like to know, gonna be running a B18B1 94 octane with forged rods, pistons and the RM cam package eventually.
Old Jan 19, 2005 | 11:01 PM
boostismycrack's Avatar
E-thug
I made 358whp on a mustang dyno @14 psi w/gt35 turbo on a sleeved 9.5:1 gsr. I felt comfortable with that on 93 octane.
Old Jan 20, 2005 | 01:52 AM
b00stedbyFastrax's Avatar
Default Re: what are the limits of pump gas and boost? (boostismycrack)
what A/F ratio and timing you guys are running on 91 pump gas?
Old Jan 20, 2005 | 04:08 AM
Boostage's Avatar
Default Re: what are the limits of pump gas and boost? (b00stedbyFastrax)
what does it matter? if you use alcohol injection you can make 600hp+ on pump gas, and alcohol is $0.77 a bottle at walmart
Old Jan 20, 2005 | 06:02 AM
The Phil's Avatar
Default Re: what are the limits of pump gas and boost? (Boostage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">what does it matter? if you use alcohol injection you can make 600hp+ on pump gas, and alcohol is $0.77 a bottle at walmart</TD></TR></TABLE>
rubbing alcohol injection?
Old Jan 20, 2005 | 06:17 AM
Boostage's Avatar
Default Re: what are the limits of pump gas and boost? (xthephilx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xthephilx &raquo;</TD></TR><TR><TD CLASS="quote">
rubbing alcohol injection?</TD></TR></TABLE>
rubbing
denatured
methanol
etc
etc...
they all work
Old Jan 20, 2005 | 06:25 AM
The Phil's Avatar
would you inject just the alcohol or mix it with water?
Old Jan 20, 2005 | 06:37 AM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xthephilx &raquo;</TD></TR><TR><TD CLASS="quote">would you inject just the alcohol or mix it with water?</TD></TR></TABLE>
IPA that you get from the drug store is already 30% water.
Old Jan 20, 2005 | 07:11 AM
The Phil's Avatar
Default Re: what are the limits of pump gas and boost? (DaX)
so you'd just buy some bottles of whatever alcohol and use them in your alcohol injection system? i kind of thought itd be more expensive...
Old Jan 20, 2005 | 07:30 AM
DaX's Avatar
DaX
Loved
Community Favorite
I'm not sure if IPA is good with its 30% water content. You also are unable to distill the alcohol out of the water when they are combined in this ratio. It's not as simple as dumping alcohol into your motor...you'll need a way to control the amount of alcohol going in, and then tune for it.
Old Jan 20, 2005 | 08:21 AM
RyanEJ8's Avatar
Default Re: (Quad-Damge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damge &raquo;</TD></TR><TR><TD CLASS="quote">anyone ever make 400whp on like 10.0.1 comp on pump 91 CA suckssss</TD></TR></TABLE>
I think hybrid901 did it on pump 93 with 10:1 C/R.
Old Jan 20, 2005 | 08:24 AM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buck02 &raquo;</TD></TR><TR><TD CLASS="quote">i made 519 on pump 91 octane
street tune on 13psi </TD></TR></TABLE>
Whaaa?
13psi?
Old Jan 20, 2005 | 08:25 AM
_entropy's Avatar
Default Re: (RyanCivic2000)
IPA is good if you're in a fix and need something to dump in quick. I got a sleeved motor for a great price, but unfortunately it was already 10:1 compression, so I run an alkycontrol meth injection kit. I buy Sunoco methanol in drums, it's about 2 dollars a gallon and I usually run it straight.
Old Jan 20, 2005 | 08:39 AM
RyanEJ8's Avatar
Default Re: what are the limits of pump gas and boost? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">
Whaaa?
13psi?</TD></TR></TABLE>
Theres a thread right here on the first page of this forum about it. He was revving to like 9500rpm.
Old Jan 20, 2005 | 08:41 AM
_entropy's Avatar
Default Re: what are the limits of pump gas and boost? (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">
Theres a thread right here on the first page of this forum about it. He was revving to like 9500rpm.</TD></TR></TABLE>
And a gigantic GT4067 + 4" downpipe doesn't hurt either
