What Bearings to Use.
Old Jan 21, 2005 | 09:12 AM
TheThiefTheKnife'NTheGun's Avatar
Default What Bearings to Use.
I am rebuilding the bottom end. I was curious about peoples expierence with different main and rod bearings. thanks
Justin
RyanEJ8's Avatar
Default Re: What Bearings to Use. (justinwipf)
Nothing but good experiences with ACL's here.
Old Jan 21, 2005 | 09:17 AM
Garcia-Racing's Avatar
ACL, if within specs.
Old Jan 21, 2005 | 01:13 PM
LoSt is BlaCk's Avatar
Default Re: What Bearings to Use. (Garcia-Racing)
acl's treat me right
Old Jan 21, 2005 | 01:15 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: What Bearings to Use. (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">Nothing but good experiences with ACL's here.</TD></TR></TABLE>
Likewise!!!
Old Jan 21, 2005 | 01:19 PM
Bulldogg83's Avatar
Default Re: What Bearings to Use. (LoStMyBoOsT)
Honda Bearings....nothing better than stock.
Old Jan 21, 2005 | 01:38 PM
Boosted Chemist's Avatar
Default Re: What Bearings to Use. (Bulldogg83)
what happens if you get acls and they are out of spec?
Old Jan 21, 2005 | 01:44 PM
GDM Z28's Avatar
Default Re: What Bearings to Use. (Boosted Chemist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist &raquo;</TD></TR><TR><TD CLASS="quote">what happens if you get acls and they are out of spec? </TD></TR></TABLE>
that has never happened to ne one i know but if one is out of spec replace it with an oem one
Old Jan 21, 2005 | 02:04 PM
T4eg's Avatar
Default Re: What Bearings to Use. (civicflnum1)
OEM
Old Jan 21, 2005 | 02:29 PM
2K_TEG's Avatar
Default Re: What Bearings to Use. (BlueHatch00)
OEM or ACL, just check and make sure they are within specs with plastigauge.
Either will serve you well.
Kyle
Old Jan 21, 2005 | 08:27 PM
Default Re: What Bearings to Use. (2K_TEG)
Thanks for the help
Old Jan 21, 2005 | 09:35 PM
V-SPEC 1's Avatar
I've seen some ACL's that's been coated, mains and rods. what do you guys think about coated bearings? I"m looking for some good bearings that are coated. Anyone know where to find them?
Old Jan 21, 2005 | 09:36 PM
Johnyquest's Avatar
I just used OEM... Nothing easier than reading the marks on the block and on the crank, and ordering the correct sizes. I still don't have a grasp on how ACL's once size fit's all bearings work... So I just used OEM. No complaints.
Matt
PS- the reason I say this is bc my OEM bearings worked out so that I have 3 different bearing sizes... one brown, two yellow... and two green.
Old Jan 21, 2005 | 10:14 PM
ComputerJLT's Avatar
Default Re: What Bearings to Use. (Johnyquest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnyquest &raquo;</TD></TR><TR><TD CLASS="quote">I just used OEM... Nothing easier than reading the marks on the block and on the crank, and ordering the correct sizes. I still don't have a grasp on how ACL's once size fit's all bearings work... So I just used OEM. No complaints.
Matt
PS- the reason I say this is bc my OEM bearings worked out so that I have 3 different bearing sizes... one brown, two yellow... and two green.</TD></TR></TABLE>
you can get over and undersized acl's too genious.
it's not one size fits all...
they just dont use the retarded *** color system honda does.
Old Jan 21, 2005 | 11:07 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bulldogg83 &raquo;</TD></TR><TR><TD CLASS="quote">Honda Bearings....nothing better than stock. </TD></TR></TABLE>
superg6819
Jun 1, 2006 06:31 AM
Andres-eh2
Feb 21, 2006 08:14 AM
Andres-eh2
Northeast (Sales)
26
Feb 17, 2006 05:28 PM
cueballsi
Feb 18, 2005 06:21 PM
eghonda
Nov 28, 2003 09:50 AM
