will this turbo satisfy my needs..............
Old Jan 21, 2005 | 04:10 AM
thelate1's Avatar
Default will this turbo satisfy my needs..............
just wandering how this setup will run?
proposed setup:
b18a(stock)
450 dsm's
walbro 255
tial 35mm
manifold ?
dsm smic
tuned with turboedit
garret t3 .42/.48
i know it's not a huge turbo, but i'm a noob to FI. all i want is a quicker car, thats fun to drive. i plan on tuning to 8-10 lbs. i'm not shooting for HP goals, b/c whatever it turns out to be i'll be happy. thoughts?
thanx
Old Jan 21, 2005 | 09:15 AM
beepy's Avatar
Default Re: will this turbo satisfy my needs.............. (thelate1)
I have a similar turbo on my car, and love it. You really don't need the external wastegate, stick with the internal for now.
Old Jan 21, 2005 | 11:21 PM
thelate1's Avatar
Default Re: will this turbo satisfy my needs.............. (beepy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">I have a similar turbo on my car, and love it. You really don't need the external wastegate, stick with the internal for now.</TD></TR></TABLE>
cool, hows the top end power? could you elaborate on your setup?
thanx
Old Jan 21, 2005 | 11:36 PM
wantboost's Avatar
Who is Mr Robot?
beepy has a kia rio, he did all of the work himself so i'll let him tell you more. I wouldnt expect alot top-end wise from a t3 of that size
Old Jan 21, 2005 | 11:45 PM
thelate1's Avatar
Default Re: will this turbo satisfy my needs.............. (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">beepy has a kia rio, he did all of the work himself so i'll let him tell you more. I wouldnt expect alot top-end wise from a t3 of that size</TD></TR></TABLE>
yeah, i know it won't be the best, but low and mid range should spool quick right?
i thought i've read that full boost should come around 3k-3.5k, true?
how about the internal gate issue, will it suffice? i'm kinda worried about creep w/ the internal gate. i'm going to get a quality manifold though, so i should'nt have any problems from that. how about porting internal gate for better flow? can i just grind it away around the hole(like a funnel, kinda)?
thanx for the help.
Old Jan 21, 2005 | 11:46 PM
wantboost's Avatar
Who is Mr Robot?
low and mid should be amazing with that turbo.
yes you can port the wg hole, just make sure not to port it too much and make the hole bigger than the flapper, while you are at it, you could modify the flapper and tack on a bigger flapper thingy.
Old Jan 22, 2005 | 12:01 AM
thelate1's Avatar
cool, good to hear. i can't wait. i do have a friend that is a machinist. he could make me a flapper thing. how big is to big, hole diameter wise? i mean i wouldn't go drastic.
thanx
Old Jan 22, 2005 | 12:04 AM
wantboost's Avatar
Who is Mr Robot?
i've seen ppl do 35-38mm flapper mods
Old Jan 22, 2005 | 09:57 AM
thelate1's Avatar
anyone else have thoughts?...........
93turbo16's Avatar
if it was me I would go a little bigger on the exhaust side. But it should be ok.
Old Jan 23, 2005 | 04:55 PM
thelate1's Avatar
Default Re: (93turbo16)
thanx
Old Jan 24, 2005 | 02:12 PM
thelate1's Avatar
Default Re: (thelate1)
does anyone know the max lbs that an internal wastegate will hold? i forget, which way do you screw the rod to increase boost?
thanx
Old Jan 25, 2005 | 01:11 AM
thelate1's Avatar
^answers?
Old Jan 25, 2005 | 01:16 PM
thelate1's Avatar
up for answers
Old Jan 27, 2005 | 03:08 PM
thelate1's Avatar
anyone?
blwnengnls
Apr 12, 2007 06:40 PM
o'malley_808
Jul 30, 2005 05:48 PM
RACEPAK
Feb 8, 2005 01:26 PM
Charles B.
Jan 29, 2002 05:55 PM
