Bore Size & Boost
Old Feb 28, 2005 | 04:24 PM
LSEGHATCH's Avatar
Default Bore Size & Boost
I recently purchased a b18a block bored to 85.5mm and was told that that could be too large to boost high, something about the sleeves being too close together. Just thought I would gain some other people's opinions or facts.
Old Feb 28, 2005 | 04:33 PM
non-VTEC's Avatar
Default Re: Bore Size & Boost (LSEGHATCH)
that is a pretty big bore to boost on........it would probably be ok if you tune it right and make sure you get NO dentonation at all.....and maybe not crank up the boost that much. the cylinder thickness is kinda thin with that big of a bore.
also good luck finding 85.5mm pistons without paying for some expensive custom peices......
Old Feb 28, 2005 | 04:41 PM
LSEGHATCH's Avatar
Default Re: Bore Size & Boost (non-VTEC)
So what psi am i going to be limited to because of this, the sleeves are jg and also has the block gaurd as well. Don't know if any of this is a factor for how much I can boost but...
Old Feb 28, 2005 | 04:49 PM
NJIN BUILDR's Avatar
30#'s with no detonation or 4#'s with detonation..
Its just the fact that you don't have much sealing area.Its not the pounds of boost its the pounds of cylinder pressure which gets insane with detonation.
Glenn
Old Feb 28, 2005 | 04:55 PM
Suprdave's Avatar
I've done 85mm w\ 24-25psi without trouble...85.5 is pushin yer luck though.
Old Feb 28, 2005 | 04:57 PM
kevino002's Avatar
Default Re: Bore Size & Boost (NJIN BUILDR)
mine is 86mm, my tunner said that it will be fine seeing that its a custom sleeve made to be 86-88mm, I am no expert but I will let you know how things go.
Old Feb 28, 2005 | 05:57 PM
LSEGHATCH's Avatar
Default Re: Bore Size & Boost (kevino002)
I wonder if I should sell this block and buy a different one then. I was looking to boost around 22 while at the track but that seems like a bad idea. So what would you reccomend I do?
Old Feb 28, 2005 | 06:19 PM
kevino002's Avatar
keep it and make it work, lol, I think you should do what you think it right.
Old Feb 28, 2005 | 06:22 PM
LSEGHATCH's Avatar
I think I should do what won't blow up if something goes wrong, being 17 and limited income from my shitty paying job, it needs to last more than a day at the track lol. I'll keep researching...
Old Feb 28, 2005 | 06:23 PM
DaX's Avatar
DaX
Loved
Community Favorite
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSEGHATCH &raquo;</TD></TR><TR><TD CLASS="quote">I think I should do what won't blow up if something goes wrong, being 17 and limited income from my shitty paying job, it needs to last more than a day at the track lol. I'll keep researching...</TD></TR></TABLE>
Man I wish I was 17 when I got into all this. I'd have a pimp *** ride by now!
Old Feb 28, 2005 | 06:27 PM
kevino002's Avatar
Default Re: Bore Size & Boost (DaX)
me too.. I would have a mean *** ride.
Old Feb 28, 2005 | 06:30 PM
wantboost's Avatar
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">
Man I wish I was 17 when I got into all this. I'd have a pimp *** ride by now!</TD></TR></TABLE>
I was 15 when i started im 18 now, now 2 cars later i have enough to buy an evo in my little civic, that tally is gonna rise by about 10k by the time paint, body and engine is done
Modified by wantboost at 7:55 PM 2/28/2005
Old Feb 28, 2005 | 08:08 PM
LSEGHATCH's Avatar
Default Re: Bore Size & Boost (wantboost)
Thanks, I think I'm going to look for a better setup for my project.
Old Feb 28, 2005 | 08:15 PM
turboEGhatch's Avatar
You'd have HG issues with 85.5MM, we did on a friends B16. Sad part is he had it sleeved at 85.5 outright and the motor was unuseable for boost. Even if you could get the HG's to stay on it, I think you would see the cylinders go out of round in short order. Stock sleeves with a good tune rock
Old Mar 7, 2005 | 06:44 PM
kevino002's Avatar
Default Re: Bore Size & Boost (turboEGhatch)
bump for more info.
Old Mar 14, 2005 | 05:28 PM
kevino002's Avatar
Dark19Acura
Oct 21, 2008 01:12 PM
ttracing03
Apr 1, 2006 02:43 PM
PIFFSTAR
Feb 15, 2005 06:49 AM
Turbo-Honda
Jan 12, 2004 03:09 AM
VaporTrail
Oct 20, 2003 05:46 PM
