97+ Prelude injectors
just a quick q, car is a 99ex, i had an idea to use the lude injectors becuase they are 320cc [correct if im wrong]. are they the same setup as the dsm, need to use a resistor, or plug right in. i wanna get rid of the dsm 450s and use something along the lines of 310-350cc area so with the afc, it wont **** with the map fuel tables too much, ideas ?
Re: (eK9aT10pSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK9aT10pSi »</TD></TR><TR><TD CLASS="quote">tahnks for the info, and would it be the same for hte 92-96 ?</TD></TR></TABLE>
No, 92-96 injectors are different. They flow more and they are low impedance (resistor box required). The clips are also different. 97+ are a minor drop-in upgrade for OBD2 Civics and Integras. Good for mild boost JRSC setups that are still running an FMU.
Sonny
Sonny
Re: (Sonny)
i fugire with boost, the 4gen ludes are a better choice, 345cc stock. and tune with afc. atleast it wont **** with the map voltage tables too much as the dsm 450cc would.
Beau Gotti
11-30-2007 03:02 PM
