boost creep using elbow
Old Mar 1, 2005 | 01:01 PM
downeyballz's Avatar
Default boost creep using elbow
i have a few questions about boost creep. on ac equal length mani (that uses an elbow to clear all ac componets) how much boost can you make with a tial 38mm before you see boost creep. i know that the elbow and small wastegate and factors in boost creep.
Old Mar 1, 2005 | 01:24 PM
beepy's Avatar
Default Re: boost creep using elbow (downeyballz)
12.14651698 pounds-force per square foot divided by 144.
But really, there are dozens of factors that affect boost creep. This question is impossible to answer.
Old Mar 1, 2005 | 06:12 PM
does any one have an ac compatible equal length + tial combination. if so what pressure did you start to see boost creep, i am looking for someone that has had eperince with a similar set up
Old Mar 1, 2005 | 06:13 PM
beepy's Avatar
Dude, you at least need to tell us what turbo you have, and what engine it is on.
Old Mar 1, 2005 | 09:50 PM
Default Re: boost creep using elbow (beepy)
gt35r, gsr motor, love fab mini-me ac manifold
Old Mar 2, 2005 | 06:43 AM
Default Re: boost creep using elbow (slow poke)
i plan on having 400hp on the street at 16 psi (which i think 38mm would be fine) but if i ever decide to turn up the boost 44mm will be neccessary. i was just wondering if anyone had a ny personal experince with a similar set up
Old Mar 2, 2005 | 11:34 AM
just because it worked for their set up doesnt mean it will work for everyone. i did ALOT of searching and most people running high boost usually go with a bigger wastegate. when searching i didnt see anyone with a set up simalar to mine. im looking for someone with experince with the same manifold
Old Mar 2, 2005 | 01:28 PM
Tinker219's Avatar
Customer with a 38mm that switched to a 44mm.
https://honda-tech.com/zerothread?id=1145542
https://honda-tech.com/zerothread?id=1114255
Not AC, but this is just an example of what I was hinting at. If it were MY car with this manifold, I wouldnt use anything smaller than the 44mm. The 38mm will probably work just fine at 1bar+, but I wouldnt want to take the chance.
ITR206 had the same thing, but comparing the 40mm to the 44mm. The 44mm cured it if memory serves correctly.
Synapse
May 1, 2007 08:42 AM
builtboostedteg
Apr 5, 2006 05:19 PM
Cowboy
Jun 16, 2003 02:12 PM
89civic1.8T
Nov 1, 2002 08:45 PM
