check valves question
Old Mar 1, 2005 | 02:51 PM
hbkxtbone's Avatar
Default check valves question
okay im using the easy route for right now..i have a LS im trying to boost. I went to the pet store and bought the check valves. on one end it says "air in" and the other side says "air out" I know this maybe a dumb question but I gotta know which way they are suppose to go...i already did the t fitting and everything just wanna know if im suppose to have the "air out" position facing the outside and the "air in" connected to silicone hose. thanks for any help
Old Mar 1, 2005 | 03:05 PM
forcefedh22's Avatar
Default Re: check valves question (hbkxtbone)
"air out" goes towards the intake manifold or any source the vacuum is coming from. those check valves dont work very well if your using them for the map sensor on obd1. If yours is on the throttle body you should have a missing link. Just a little advice.
Old Mar 1, 2005 | 03:26 PM
Terrible One's Avatar
i thought the air in should be connected to the vacuum source, oh well. ditch your check valves and fmu setup. uberdata
Old Mar 1, 2005 | 04:29 PM
hbkxtbone's Avatar
Default Re: check valves question (orig1nalkhmersta)
thanks guys its a obd2 no wonder it wouldn't boost i had it the other way around...
Old Mar 1, 2005 | 04:30 PM
Turbowa's Avatar
I second the air in part. You will have to run about 4-5 check valves to be able to run 8-9 lb's of boost. Your best bet it to get a missing link.
JBirch_97Prelude
Nov 3, 2008 08:23 AM
tiN_cAn
Suspension & Brakes
Sep 19, 2005 03:04 PM
bennyhonda7
May 11, 2005 11:38 AM
turbohybridhatch
Mar 17, 2005 07:05 PM
integraracer94
Jun 2, 2002 06:34 PM
