why aren't turbos made like this:
on the exhaust side, have a 2.5 inch gear connected to the exhaust turbine, and on the intake side, have a .5 inch gear connected to the intake turbine. i know this would offset the whole turbo, and it would get rid of lag, although the only downside i could see is that you'd be using or needing a wastegate rather quickly...
any info?
any info?
Because the turbo NEEDS to spin fast to generate the power it needs for the compressor. The shaft torque is very small, so it needs a high RPM to generate the power.
Plus gears rob power when they transmit torque, especially at high RPM. So you'd have additional losses. Besides - it'd still have the non-linear turbine/compressor response to deal with(which is the big reason why turbos have "lag").
There's a reason the engineers that designed them did it the way they did - it's the best way to do it(with our current technology at least).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Def »</TD></TR><TR><TD CLASS="quote">Because the turbo NEEDS to spin fast to generate the power it needs for the compressor. The shaft torque is very small, so it needs a high RPM to generate the power.
There's a reason the engineers that designed them did it the way they did - it's the best way to do it(with our current technology at least).</TD></TR></TABLE>
Turbos were designed a long time ago. I'm sure we have better technology today than they did then considering they were on cars before we even had Autocad.
edit: i'm not saying it would work, i'm just saying that it doesn't hurt to rethink things once in a while.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njn63 »</TD></TR><TR><TD CLASS="quote">Turbos were designed a long time ago. I'm sure we have better technology today than they did then considering they were on cars before we even had Autocad.
edit: i'm not saying it would work, i'm just saying that it doesn't hurt to rethink things once in a while.</TD></TR></TABLE>
Turbos are constantly being updated and refined. The aerodynamics of the blades are always trying to be improved - hence the new GT series wheels that make more power and have less lag.
Buying a brand new $1,400+ turbo right now gets you the absolute BEST centrifugal turbine/compressor technology available to the consumer market, and software way more complex than AutoCAD was used in their development.
string
Sep 12, 2006 04:04 PM
