dsm 450cc duty cycle
Old Feb 26, 2005 | 09:48 PM
eK9aT10pSi's Avatar
Default dsm 450cc duty cycle
just a thought, the stock injectors of a civic is 240cc @ 38psi at idle. what are the dsm injectors rated at? 450cc @ _ _ psi ?
Old Feb 26, 2005 | 11:22 PM
DragSource's Avatar
Not sure, but running them on my B-Series. . . with about a 240 hp setup, they were not running very much duty cycle at all. They are pretty large.
Old Feb 26, 2005 | 11:57 PM
W O T's Avatar
Default Re: (DragSource)
Im looking to push them to 300-320whp on my sohc, I dont mind upping the fuel pressure a little
Old Feb 27, 2005 | 12:09 AM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: (W O T)
I'm running 50psi idle on my B18C1
260WHP @6.5 PSI
Old Feb 27, 2005 | 06:02 AM
CroteTurbo's Avatar
Default Re: dsm 450cc duty cycle (eK9aT10pSi)
Mine are at 50psi fuel pres = 295 whp@10.5 psi near 90% Duty cycle
Old Feb 27, 2005 | 06:32 AM
USDM 4G VTEC's Avatar
weird
i got 43psi
at 10 psi, and pig rich (under 10 AFR) on stock fuel pump and i am on 58% duty cycle
Old Feb 27, 2005 | 10:25 AM
W O T's Avatar
Default Re: (USDM 4G VTEC)
295whp 90% duty and 50psi? Doesnt sound even close to right
Old Feb 27, 2005 | 07:24 PM
eK9aT10pSi's Avatar
Default Re: (W O T)
im runnin mine at 38psi idle with the walbro 255lph at 7 psi with -39% cor on the afc. im thinkin of gettin some prelude 320cc injectors so it doesnt **** with my map tables too much, ideas?
Old Feb 28, 2005 | 04:31 AM
b_ron007's Avatar
most wont like what i was running, but i ran 70psi at idle, i had a WALBRO 255 high pressure fuel pump, so i figured it could handle it..... it can! but i was also running AEM EMS. at 15psi i was at a 70% injector duty cycle. this was on dsm 450 black tops. i had full controll over them, no problems at all!
Old Feb 28, 2005 | 12:40 PM
eK9aT10pSi's Avatar
Default Re: (b_ron007)
what setup would cause use to run them taht high, even with the ems being able to control them to limit the flow?
Old Feb 28, 2005 | 12:58 PM
boostedb16a3's Avatar
hope this helps in answering your questions
http://precisionturbo.net/techinfotext.php?aid=11
this is page 2 of that discussion
http://precisionturbo.net/techinfotext.php?aid=22
v.i.gsr
May 12, 2011 06:39 PM
dublaaciv
Nov 1, 2005 07:08 PM
freddy_hung
Aug 29, 2003 02:38 PM
Jared
Jun 5, 2003 06:30 PM
asianspeed
Aug 29, 2002 11:57 PM
