comparing turbos
Old Feb 25, 2005 | 09:44 AM
ochsy03's Avatar
Default comparing turbos
i got a 99 civic si with a t3/t4 turbonetics turbo(drag gen III kit) and im buildin my motor right now and thinkin about upgrading my turbo. right now im puttin out 222whp at 8psi
i want anywhere from 375+ whp
heres the turbos i was looking into
SC34
GT32
GT28rs
my question is...what would be the differnent whp #'s for each turbo at about 18-19 psi?
Old Feb 25, 2005 | 09:46 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: comparing turbos (ochsy03)
well, the gt28rs wont get you to 375, so scratch that one off of the list. I'd go with the gt32. its basically the garrett gt wheels in a journal bearing chra. If i remember correctly it made 8psi by 4200rpm on a stock gsr. The nice thing about the gt is that it will make nice power on the topend, where teh sc34 tends to die off
Old Feb 25, 2005 | 11:06 AM
PrettyLude's Avatar
gt32
Old Feb 25, 2005 | 11:14 AM
ochsy03's Avatar
Default Re: (PrettyLude)
alright guys thanks for the advice
Old Feb 25, 2005 | 11:16 AM
98lude-t's Avatar
Default Re: (ochsy03)
sc 61 they make topend power
Old Feb 25, 2005 | 12:24 PM
ochsy03's Avatar
Default Re: (98lude-t)
yea i was just gonna ask about the SC61....would that be better for my setup?
Old Feb 25, 2005 | 07:00 PM
tony n.'s Avatar
sc61 make crazy power
Old Feb 25, 2005 | 08:05 PM
rmcdaniels's Avatar
Default Re: comparing turbos (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">well, the gt28rs wont get you to 375, so scratch that one off of the list. </TD></TR></TABLE>
I made almost 380 on a GT28RS, plus I had way more torque across my RPM range than I had with a bigger turbo. If you want power that you can use outside of a dragstrip (and at a dragstrip too), I'd go with a GT28RS. I've seen guys with SC61's make crazy power, but it takes forever to spool up. I had far more torque (20-60 lb/ft) below 5000 RPM with the GT28RS than with my GT3071R.
Old Feb 26, 2005 | 06:21 PM
ochsy03's Avatar
Default Re: comparing turbos (rmcdaniels)
right now heres my setup
b16a2
drag gen III turbo
hondata s200b
aem fuel rail
aem fuel pressure regulator
aem fuel filter
arp main studs
arp head studs
walbro 255lph fuel pump
tial 38mm wastegate
RC650cc injectors
Golen eagle sleeves
eagle rods
wiseco pistons 9:1
ITR cams or ctr cams
not sure exactly what brand im gonna use: springs, retainers, valves
heres the clutches ive been looking into:
ACT-XTSS
clutchmaster stage 3
ACT Xtreme Duty clutch, Pro Street Flywheel
i want 375whp+...any adive on my setup would be greatly appreciated.the stuff in bold is what im gonna buy
Old Feb 26, 2005 | 07:21 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ochsy03 &raquo;</TD></TR><TR><TD CLASS="quote"> not sure exactly what brand im gonna use: springs, retainers, valves </TD></TR></TABLE>
supertech is a pretty good brand, and can't be beat for the price
Old Feb 26, 2005 | 07:23 PM
DefiantGSR's Avatar
Default Re: comparing turbos (PrettyLude)
I'd keep a stock head setup based on the turbo he has.
Old Feb 26, 2005 | 08:07 PM
ochsy03's Avatar
Default Re: comparing turbos (DefiantGSR)
yea my head is gonna be pretty much stock.....im still lookin for alot of help on my setup and wanna know from people who have experienced high hp motors and what parts they used.
also what are some good online stores to order parts from?
Old Feb 26, 2005 | 10:03 PM
DefiantGSR's Avatar
camp1320.com
That's his HT SN...he sells **** for crazy low prices.
Old Feb 27, 2005 | 08:46 AM
rmcdaniels's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DefiantGSR &raquo;</TD></TR><TR><TD CLASS="quote">camp1320.com
That's his HT SN...he sells **** for crazy low prices.</TD></TR></TABLE>
I've bought stuff off of camp1320, great prices and no problems, plus he can get about anything.
Old Feb 27, 2005 | 08:54 AM
rmcdaniels's Avatar
The T3/T4 included in the Drag Gen III kit is efficient up to about 450 HP, so it should be fine for your HP goals.
My ACT XTSS started to slip when I got above 370 WHP, I upgraded to the XTR6 and it holds fine now.
camo_crx
Jul 11, 2005 09:22 PM
riceburnah
Jul 14, 2004 08:02 PM
H1PNOT1C PRELUDE
Feb 9, 2004 07:49 AM
b20turbovtec
Feb 3, 2004 04:07 PM
Cyber ITR
Dec 2, 2002 02:55 PM
