83mm gsr injector question
i have a 83mm gsr and a lot of people say not to run the stock injectors because it will burn up to much oil and not good for the pistons, wondering if i should just buy a set of 310cc and use a wideband to break in the motor before putting the turbo on.
Re: 83mm gsr injector question (Hockey27925)
I started my 83mm GSR on 1600 CC PTE injectors. Idled for 15 minutes and hit the dynos. 8000 miles later I have <1% leakdown. I've never seen a motor that was babied for break in have that good of leakdown later on.
Re: 83mm gsr injector question (Muckman)
so should i run stock injectors with my 255 fuel pump n aem frp n fuel rail, and just tune it using the fpr n the wideband
Who is Mr Robot?
you cant really "tune" anything involving boost with stock injectors, they're just too small. and just tweaking the fpr wont give you a consistant afr throughout the powerband
Re: 83mm gsr injector question (wantboost)
no im not going to tune the car for turbo im just guna break in the motor without the turbo for a while, so i want to tune it without the turbo and im just guna use the frp and 255 to tune it for now and i wanted to know which size injectors to run
