b18c1 jrsc w/ 01' itr cams? has anyone done this
ive posted on theoldone.com and host boards and still haven't found a definite answer. Im installing a jrsc on my gsr but im wondering if I would benefit from 01' itr cams, and if so how much (hp category). I was told that I may see some gains with adjustable cam gears but im wondering if its worth the trouble? These cams are just sitting in my room (was originally going in my na setup)
If its a minimal gain I might as well sell them and put the money towards something else.
If you are unsure please do not post.
Thanks
Here is my setup:
stock b18c1 motor
ill be using chipped obdI p28 w/ uberdata
jrsc hoping to get mvm pulley (shopping for rc 440's)
hondata IM gasket
comptech icebox w/ stock rubber intake arm
jdm 4-1
smsp 2.5" carsound cat
2.5" custom catback
Thanks
Here is my setup:
stock b18c1 motor
hondata IM gasket
jdm 4-1
2.5" custom catback
Re: b18c1 jrsc w/ 01' itr cams? has anyone done this (m R g S r)
We have found GSR cam ITR exhaust cam has made the most power. I would cams gears either way. On average 10whp is what we've seen over just ITR or GSR.
Re: b18c1 jrsc w/ 01' itr cams? has anyone done this (CRVRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRVRX »</TD></TR><TR><TD CLASS="quote">We have found GSR cam ITR exhaust cam has made the most power. I would cams gears either way. On average 10whp is what we've seen over just ITR or GSR.</TD></TR></TABLE>
Do you mean GSR intake cam and ITR exhaust cam?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r »</TD></TR><TR><TD CLASS="quote">I don't think it will hurt you at all. . .are you tuning it>
Yes ill be using uberdata.
If I were to use just the itr exhaust cam would I need cam gears?
I thought the jrsc itr made a lot more power vs the gsr
I know there might be some variables to these dyno plots but the gsr is up on hp and tq
GSR
ITR
GSR
ITR
GSR cams are known to be better for Boost.... ITR cam would actually have a negative effect... ITR is meant to be an NA beast...
with NA applications Exhaust/Intake valve overlapping helps flow with a sort of scavanging effect... This would be disasterous for boosted applications!!
Re: (Dangger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dangger »</TD></TR><TR><TD CLASS="quote">GSR cams are known to be better for Boost.... ITR cam would actually have a negative effect... ITR is meant to be an NA beast...
Riiiight. .
Riiiight. .
Re: (Dangger)
with NA applications Exhaust/Intake valve overlapping helps flow with a sort of scavanging effect... This would be disasterous for boosted applications!!</TD></TR></TABLE>
I know that statement is easily falsifiable and its a myth that gets thrown around here and over the internet. I recall seeing a dyno of a turbo b16 (here in the FI forum) w/ and w/ out itr cams, and he gained hp. Im just wondering if ill have similar/better results on a s/c.
Re: (SneezR)
I am using GSR cams in my setup with Skunk2 cam gears, the cam gears alone will add HP as long as you are adjusting them during your dyno tune.
I've heard and read all sorts of stuff about ITR cams in boosted applications, but the only way you will find out if you make or lose HP is to do the job yourself and install the ITR cams with some adjustable cam gears and DYNO TUNE IT...that is the only true way you will ever know...
Re: (Blue-Civic-Hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blue-Civic-Hybrid »</TD></TR><TR><TD CLASS="quote">I am using GSR cams in my setup with Skunk2 cam gears, the cam gears alone will add HP as long as you are adjusting them during your dyno tune.
This has already been done. Mike Marsey (Rboosted717) took his very well tuned JRSC'd ITR on the dyno and then swapped in GS-R cams and retuned. He lost power.
Terry (Boostfed) put ITR cams in his turbo B16A2 and retuned. He gained power.
Sonny
Sonny
Re: (SneezR)
i believe the ITR cams do make more power, but thats if u wanna squeeze as much hp u can out of the motor then its a good investment. seeing i dont have the money to put itr cams in, i think my gsr cams do fine with the supercharger.
heres another good question, which cams (oem/aftermarket) you think would make the most HP with a jackson racing supercharger on a b18c1. anyone know/ or has actually seen/done this with proof of hp gains? a head rebuild is always in the future, and new cams would be fun to tinker with.
Guys...just think about the setup.
a SC setup doesn't have the turbine to restrict exhaust flow like a turbo charger. You have very little back pressure in the exhaust stream and are just at the mercy of the size/flow of your exhaust.
Thus adding any N/A cams with more duration and lift will make more power with SC boost respectively.
Re: (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson »</TD></TR><TR><TD CLASS="quote">Guys...just think about the setup.
Thats why its a supercharger and not a turbo...duh'
ITR cams should do really good, just make sure that your dyno tuned and not trying to go for peak HP...go for longevity.(sp?)
Re: (PLAGUEDDB7)
itr on any setup will make more if tuned properly with cam gear adjustments and ems tuning
gsr cams will not pull as hard in the upper revs as the itr cams will, its been proven time and time agian on this board
use the search feature, although most of the setups that used the itr cams were turbo'd, i highly doubt you will lose power with itr cam plus proper tuning
basically tuning with the cam gears and ems and use the search feature
goodluck with it
goodluck with it
