cluster questions
Old Feb 27, 2005 | 08:11 AM
birz's Avatar
Default cluster questions
when I start the car no needles move in the cluster the rpm, the fuel, and the temp dont move at all. Where does the cluster take his rpm signal from? the ecu directly? the only things working on the cluster looks like to be the batterie light and the srs light. I think the engine lihgt doesnt work either cause the wire of the map signal was cut on the ecu (pin D17) and it didn't even throw a cel. what could be the causes? where can I find wiring diagram for the cluster? btw its an EG with a b18b
Old Feb 27, 2005 | 08:59 AM
beepy's Avatar
Default Re: cluster questions (birz)
That is going to be hard to diagnose, especially since it seems that you have modified the existing wiring.
I would check all the fuses. After that, well, my first guess would be the gauge power wire is damaged. All the gauges (and the CEL) are supplied switched power from a single short connector. The battery and SRS and supplied with seperate power.
Old Feb 27, 2005 | 12:19 PM
birz's Avatar
Default Re: cluster questions (beepy)
can someone show me wich fuse control the needles and check engine light please?
or a link to the manual of civic EG
tia
Old Feb 27, 2005 | 01:16 PM
XSIintegra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">I would check all the fuses. After that, well, my first guess would be the gauge power wire is damaged. All the gauges (and the CEL) are supplied switched power from a single short connector. The battery and SRS and supplied with seperate power.</TD></TR></TABLE>
Agreed
Old Feb 27, 2005 | 01:41 PM
birz's Avatar
Default Re: cluster questions (XSIintegra)
do you have any pics of that short connector?
Old Feb 27, 2005 | 01:48 PM
NVturbo's Avatar
O.G. triple O.G.
I would check all the fuses. .</TD></TR></TABLE>It is one of the fuses located at the under-dash fuse box. Bad or loose fuse will cause this problem.
Arcal
Sep 17, 2013 11:43 PM
JaayDeeEmm
Dec 9, 2012 10:47 AM
djslim23
Apr 3, 2012 05:30 PM
B16aCRXSi
13
Apr 24, 2009 01:24 PM
mugencivic94
Aug 17, 2007 09:54 AM
