Question about Greddy return fitting...???
Old Feb 27, 2005 | 09:22 PM
XxSOHCDriVerxX's Avatar
Default Question about Greddy return fitting...???
Sup honda-tech....im runnning a Y8 oil pan on my Z6 with the greddy return fitting, but we had to ghetto-rig it just to make it fit. so now its leeking. i didnt have a chance to take off the fitting of the Y8 pan, so i have a Z6 pan to do this on......so here is what i need.....WHAT SIZE ARE THE THREE HOLES THAT I NEED TO DRILL FOR THE FITTING TO FIT???
Old Feb 27, 2005 | 10:23 PM
Ri5e's Avatar
Default Re: Question about Greddy return fitting...??? (XxSOHCDriVerxX)
my friend had the same leaking problem. he just jbwelded the edges and it stopped leaking
Old Feb 27, 2005 | 11:09 PM
Default Re: Question about Greddy return fitting...??? (TurboSmart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboSmart &raquo;</TD></TR><TR><TD CLASS="quote">my friend had the same leaking problem. he just jbwelded the edges and it stopped leaking</TD></TR></TABLE>
its not leaking from the fitting, its leaking from where the oil pan gasket is. so i just wanna use a Z6 pan.
Old Feb 28, 2005 | 01:35 AM
Ls InTeGrA RaCeR's Avatar
try getting a new oil pan gasket. they're only $15
Old Feb 28, 2005 | 02:22 AM
Sivik's Avatar
^^^ what he said
Old Feb 28, 2005 | 02:35 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Question about Greddy return fitting...??? (Ls InTeGrA RaCeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls InTeGrA RaCeR &raquo;</TD></TR><TR><TD CLASS="quote">try getting a new oil pan gasket. they're only $15</TD></TR></TABLE>
Do this, and only hand tighten the nuts/bolts that hold it on. My first time doing an oil pan gasket, I screwed up 3 in a row.
Old Feb 28, 2005 | 03:32 AM
m R g S r's Avatar
Default Re: Question about Greddy return fitting...??? (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">
Do this, and only hand tighten the nuts/bolts that hold it on. My first time doing an oil pan gasket, I screwed up 3 in a row.</TD></TR></TABLE>
So your first second and third time
Yea. . .Don't tighten it too much or the gasket will pinch .. .
Old Feb 28, 2005 | 04:23 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Question about Greddy return fitting...??? (m R g S r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">
Yea. . .Don't tighten it too much or the gasket will pinch .. . </TD></TR></TABLE>
First I tried reusing the old one...it leaked.
I bought a new one...it still leaked.
I tried reusing the new one with RTV...it still leaked.
I went and bought ANOTHER one and only hand tightened everything and it worked like a charm. It was a bitch to get the RTV'd pan off the block. It was a bitch to get the RTV off the pan.
I was torquing the nuts so tight I actually broke a stud on one of the first few attempts.
Old Feb 28, 2005 | 06:12 AM
i would do that but the Y8 pan doesnt fit really good. and i couldnt get the flywheel cover on when i put on the Y8 pan. anyone know what size i should drill????
i dont wanna take off the fitting then letting my car sit till i measure the size. i just need to know what size so i can drill the Z6 pan and put it on the same day.
thanks for the info
Old Feb 28, 2005 | 09:15 AM
ttt
Old Feb 28, 2005 | 12:51 PM
up
Old Feb 28, 2005 | 03:21 PM
Old Feb 28, 2005 | 05:09 PM
anyone?????
Old Mar 1, 2005 | 05:51 AM
jdfkgdfhk,xfhjsf
Old Mar 1, 2005 | 08:00 AM
Cruiser G's Avatar
its probably not helping that it doesnt have the slope it should. It should be installed with the flange strait so the nipple is angled up a bit. that will probably be fine though as long as you seal it real good.
Old Mar 1, 2005 | 11:00 PM
MIDnightblackDA's Avatar
Default Re: Question about Greddy return fitting...??? (Cruiser G)
will someone just tell my brotha what size hole to drill?
Old Mar 1, 2005 | 11:42 PM
integ22's Avatar
This is for a GSR so dunno if it's the same. Check out steps 34 & 35.
http://www.deepstaged.net/turbogsr.htm
b17a1teg
Mar 30, 2011 02:18 PM
MurtazaDSM
Nov 6, 2009 10:14 AM
kaychi
Jan 27, 2009 06:34 PM
r1ch1e
Mar 28, 2006 10:45 AM
