low compression numbers good for boost
I just did my compression test on b18c 160 across the board I added a cap full of oil and got 190-195 across the board. Do you guys think this motor is healthy enough for boost.
TIA
Chris
cyl 1 160/195 cap of oil
cyl 2 160/195
cyl 3 160/190
cyl 4 160/190
Modified by Cole D at 12:05 AM 6/24/2007
TIA
Chris
cyl 2 160/195
cyl 3 160/190
cyl 4 160/190
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dual Cam Racing »</TD></TR><TR><TD CLASS="quote">how many cranks did u do? there at least consistant</TD></TR></TABLE>
10 cranks
10 cranks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by methos713 »</TD></TR><TR><TD CLASS="quote">I never heard of the "cap of oil" method, explain please? </TD></TR></TABLE>
It is common method to see if the compression rises with some oil sealing the rings.Boost that thing too its consistent and that is good enough.
when doing a compression test after the intial test you can put a lil oil in each cylinder and test again, depending on the difference of numbers for the second test kinda of tells you how worn your rings are.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by methos713 »</TD></TR><TR><TD CLASS="quote">didn't know that...thanks.</TD></TR></TABLE>
you learn something new everyday on HT, LOL
Fat Chick Magnet
Nov 22, 2006 09:52 PM
nekoabandoned
Jul 24, 2006 03:39 PM
