Real quick question about the wastegate.
Old Jun 21, 2007 | 08:18 PM
The Dirty EJ1's Avatar
Default Real quick question about the wastegate.
On the my wastegate i have two ports, are they both suppose to be connected or does it
matter? oh and where does the lower vacuum port suppose to go if needed? THANKS
Sorry I don't know much about the wastegate so don't murder me on the subject.
Old Jun 21, 2007 | 08:27 PM
japan4racing's Avatar
the top port is for a boost controller just hook up the bottom port if you dont have one.
Old Jun 21, 2007 | 09:06 PM
vaporboy12's Avatar
Default Re: (japan4racing)
the bottom port just to manifold pressure... the top port is not used unless you have a ebc
Old Jun 23, 2007 | 12:44 AM
Default Re: (vaporboy12)
Ok I hooked up the vacuum line to the lower port and I couldn't build boost and the car ran kinda rough... WTF?... So I hooked to back up to the top port and I build boost and every thing is smooth but I spike over 10lbs and I my ecu cuts the boost at 10 (to be on the safe side)... So I dont know what to do... Any help is very much appreciated!
Old Jun 23, 2007 | 07:47 AM
Default Re: (The Dirty EJ1)
bump.
Old Jun 23, 2007 | 09:19 AM
boostedcivicsir's Avatar
Mr. Badwrench
if you run just a line to the top, boost will hold it shut.
where is your boost reference?
Old Jun 23, 2007 | 02:11 PM
Default Re: (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">if you run just a line to the top, boost will hold it shut.
where is your boost reference?</TD></TR></TABLE>yeah i was wondering why id boost 10lbs+ when theres only a 3lbs spring inside the wastegate..... the gaskets that i used for the wastegate looked REALLY old and crappy. Could this possibly be a reason behide the lower port not working PROPERLY? Leakage? Oh and right now im just trying to get every thing running before I put the bigger spring in so 3lbs ....
thanks
mengy007
Aug 10, 2007 03:21 PM
TunerShark
Dec 27, 2006 06:00 PM
spoon95eg
Jan 15, 2006 05:15 PM
boostedel
Feb 22, 2003 02:37 PM
boosted hybrid
Mar 1, 2002 05:44 AM
