A quick Question???? someone please help!!!!
Old Jun 26, 2007 | 09:47 AM
superhatchbackbros's Avatar
Default A quick Question???? someone please help!!!!
hey everyone, my question is do i need a missing link? i have a check engine light on with no codes on my ecu. also a lil studdering when i hit the gas.. i heard these are all signs of the map sensor so i would need the missing link. i have a full chipped pm6 with turbo edit from xenocron.com. i guess what im asking is do i need a missing link if i have a chiped ecu? thanks in advanced...
Old Jun 26, 2007 | 10:56 AM
can someone please help??
Old Jun 26, 2007 | 10:59 AM
DaveF's Avatar
Default Re: (superhatchbackbros)
no you dont need a missing link, your map sensor needs to be able to tell the ecu, if it see's boost or not... to give it the proper fueling/
what is your CEL for?
sounds like you need to get a tuneup. and possibly check the tps for correct voltage.
Old Jun 26, 2007 | 11:08 AM
ok thanks.. i think it might be on bc i see a code 10 on the ecu which is the idel temp sensor.. and ya i have a tune up and correct volts to the tps. thanks again.
chrisfromsrq
Sep 26, 2009 12:20 AM
CarpAngler
Feb 4, 2005 05:30 AM
Vinhtran17
Mar 30, 2004 09:30 PM
16STCRX
12
Oct 21, 2003 11:05 AM
JM Performance
Dec 5, 2001 09:30 AM
