F22 Pistons & Rods Help
Old Jun 24, 2007 | 05:44 AM
UK Accord's Avatar
Default F22 Pistons & Rods Help
Who's running forged pistons and rods in their F22's?
Let us know what your running and where you purchased them from, prices etc.
Cheers.
Old Jun 24, 2007 | 07:10 PM
sigmiester's Avatar
Default Re: F22 Pistons & Rods Help (UK Accord)
http://www.raceeng.com 1350 for rods rings bearings pistons. wiseco pistons carrillo rods king bearings cp piston rings i believe
cheers
Old Jun 25, 2007 | 10:17 PM
UK Accord's Avatar
Nobody else running a built F22?
Modified by UK Accord at 12:47 PM 6/26/2007
Old Jun 26, 2007 | 10:22 AM
sigmiester's Avatar
Default Re: (UK Accord)
uh... ok? i know ur across the pond and u speak the queens english, but i gave u a website.... an amount.... what company everything was, what more do u want????
Old Jun 26, 2007 | 10:29 AM
UK Accord's Avatar
Default Re: (sigmiester)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sigmiester &raquo;</TD></TR><TR><TD CLASS="quote">uh... ok? i know ur across the pond and u speak the queens english, but i gave u a website.... an amount.... what company everything was, what more do u want????</TD></TR></TABLE>
Calm down dude instead of typing "nobody running a built F22" I should of typed "nobody else running a built F22"
Thanks for your input I had already heard of those guys but thanks anyway. So what set up are you running?
Old Jun 26, 2007 | 10:44 AM
prelittlelude's Avatar
any h23 rod will work for the f22, and the f22 also has the same compression height as the h23 but the bore is 2mm smaller. there arn't alot of shelf pistons for the f22. alot of times you can get them custom ordered, but you can check th ebig suppliers , JE CP weisco, etc. some stock them as shelf.. i can't remember off the top of my head.
Old Jun 26, 2007 | 10:59 AM
sigmiester's Avatar
Default Re: F22 Pistons & Rods Help (prelittlelude)
i'm sorry man its just you know some people on here you help out and they slam you after you have helped out, i should have realized it was a typo, my bad. I am running the above mentioned and the whole DSM setup 16g mani and injectors. I just finised a rebuild on the engine and am in the process of breaking it in. In about a week i am going to go get it tuned using ECtune. What are your goals with your engine?
Old Jun 26, 2007 | 11:25 AM
UK Accord's Avatar
Default Re: F22 Pistons & Rods Help (sigmiester)
I was gonna run my set up on standard internals but during tuning the car was making around 240 lbs tq at around 4000rpm then it all came to a sudden halt and we are just in the process of taking off the head to see what's happened.
The car still runs but there is compression in the sump.
So if theres any piston damage we may aswell go for forged pistons and rods as they gonna have to be changed.
I'll be happy with a solid 250 - 300bhp reliable daily driver.
What goals are you aiming for?
Does anyone know if all the F22's share the same pistons? As mine is an F22Z2 which I don't think you got in the US.
I'm pretty sure the pistons are all the same.
Old Jun 26, 2007 | 11:31 AM
sigmiester's Avatar
i got the same goals. my car is my daily driver so i need it to be more reliable then fast for now. I would be real pleased with 250 to 300. i think they are all the same but if u know the specs of your rods and pistons there is a page in the prelude forum under the FAQ thread that has all the specs of every rod and piston for the american f and h series.
Old Jun 26, 2007 | 01:47 PM
Bboy_Trevstuh817's Avatar
I have a built h23!
Old Jun 28, 2007 | 11:41 PM
SuperSlow's Avatar
IIRC, the cheapest way to go is to either choose h23 forged pistons like prelittle said, and go custom pistons. Otherwise you can go raceeng.com expensive forged f22 rods (carillo, crower) and pistons.. Either way, it ends up not being too cheap for the parts.
Somehow, I remember people using b18/b20 forged internals as the cheapest route... but I can't remember if it was just the rods or the pistons or both...
I am in the process of deciding on this as well. Hope somebody will chime in.
Old Jun 29, 2007 | 01:10 AM
UK Accord's Avatar
Anyone else out there with any other ideas?
Old Jun 29, 2007 | 05:11 AM
twkdCD595's Avatar
Are you planning to sleeve?, I would asume not because of the stock sleeves are pretty strong so...
Well you could go with some h23 rods and custom pistons, which gives you a variety of choices for manufacturers and prices.
You could also go with h22 rods and custom pistons, if you do that you need to make sure the piston manufacturer moves the wrist pin to compensate for the slightly longer rods length the h22 rods have.
Old Jun 29, 2007 | 05:58 AM
UK Accord's Avatar
Definatley not gonna resleeve.
Old Jun 29, 2007 | 07:27 AM
sigmiester's Avatar
Default Re: (Mr Wonderfull)
i would say just give raceeng.com a call and go from there. All of these custom setups are going to cost as much as then setup from raceeng.com. i am not knocking anyone elses idea. I just looked all of these things up and raceeng.comis pretty cheap for what you get and they are really fast in shipping i had all my stuff withing two days. they have everything for the f22 in stock and theres no work on trying to move the wrist pin or measure out each rod cause they have everything ready for the f22. this is just one of those areas where your not oging to be able to save a ton of money or any at all for that matter.
Old Jul 1, 2007 | 07:17 AM
UK Accord's Avatar
Has anyone tried these rods?
http://cgi.ebay.com/ebaymotors...ZWDVW
Old Jul 1, 2007 | 08:49 AM
spoolin turbo s's Avatar
they definately look beefy enough for 300-400 you are thinking about
UK Accord
Jul 1, 2007 09:12 AM
d16dcoe45
Sep 27, 2006 05:15 PM
allmotor99lude
Jan 4, 2006 11:37 AM
ntegls
Feb 22, 2004 06:11 PM
