car running on 2 cylinders help
Old Jun 25, 2007 | 02:51 PM
lsvtechatch92's Avatar
Default car running on 2 cylinders help
car is only running on cylinder 3and4 1 and 2 are not working... tried new plugs wires and dizzy, checked timing and i have good compression in all cylinders.. the injectors are good any help
Old Jun 25, 2007 | 03:03 PM
agrn93ls's Avatar
Default Re: car running on 2 cylinders help (lsvtechatch92)
make sure your firing order is correct. one easy way to see is just swap the #1 and #2 wires see if it still misses, check cam timing, check for spark to those cylinders, check for fuel injector signal, one wire will be positive at all times the other wire will flash a ground signal on and off. the wire that is the same color on all injectors is positive power to all. start there. and reply
JDMeFBOI
11
Feb 20, 2011 06:46 AM
TwoKSiR
Sep 14, 2010 03:25 PM
GSR936
Dec 2, 2008 08:18 AM
lsvtechatch92
Jun 25, 2007 07:55 PM
CrX1988Zc
Aug 23, 2002 06:22 AM
