Lumpy idle after warm up.
Old Jun 26, 2007 | 08:20 PM
Mr.Death's Avatar
Default Lumpy idle after warm up.
For the last year or so my idle has been lumpy AFTER she warms up (150 degrees). The setup is CRX, d16z6 with gt28r for what its worth. I've cleaned out the IACV as I thought that was the culprit but nothing has changed. If I unplug the temp sending plug on the block the idle raises up to 1500 and stays constant with no hesitation which leads me to believe the temp sensor is working(or no???). If I unplug the IACV plug the car wants to die which seems ok cause no air is getting past the throttlebody when the IACV shuts. Right?? Anyhow I was thinking would the fact that the turbo coolant line which goes from the turbo to the FITV then the IACV have anything to do with my prob as the 2 are seeing very hot coolant causing the sensors to tell the ecu to dump fuel?? Just a shot in the dark on that last one. The car also does not throw any codes. Anyhow any help or whatever is greatly appreaciated. Bad 02 sensor maybe???
Thanks for reading.....
Rick
Old Jun 26, 2007 | 09:25 PM
mtber's Avatar
Default Re: Lumpy idle after warm up. (Mr.Death)
What size injectors are you running ?
Old Jun 26, 2007 | 09:34 PM
Mr.Death's Avatar
DSM 450's
Old Jun 26, 2007 | 10:01 PM
mtber's Avatar
Default Re: (Mr.Death)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Death &raquo;</TD></TR><TR><TD CLASS="quote">DSM 450's </TD></TR></TABLE>
It sounds like you maybe idling lean. Contact your tuner to have him hookup a wideband to check out if you need some adjustments made.
Old Jun 27, 2007 | 07:50 AM
Mr.Death's Avatar
Default Re: (mtber)
It's not the tune. I did have my tuner check things out and everything look good. Mind you when the car is cold the idle is perfect, it's only after the car is warmed up that it gets lumpy. Please help!
Old Jun 27, 2007 | 08:07 AM
Chris Tune's Avatar
it is the tune...
Old Jun 27, 2007 | 08:10 AM
Minor Threat's Avatar
Do you have a known good IACV you could test with? Sometimes cleaning them out isn't enough.
It doesn't sound like it's an issue with the tune, unless whatever software you're/your tuner is running has it's IACV calibrations set wrong.
Old Aug 23, 2007 | 08:46 PM
Mr.Death's Avatar
Default Re: Lumpy idle after warm up. (Minor Threat)
So I tried a different IACV and still my idle is lumpy. Like every couple of seconds randomly it wants to lump out. Keep in mind it doesn't surge at all( idle up and down). It can't be the FITV as that controlls the idle when the engine is cold. Also this happens right when my cars temp reaches 150 degs which leads me to believe that this is sensor related. The 02 sensor maybe??It reacts differently at different temps. Anyone else wanna try and help out???? I'm f'n clued...
Please and thank you.
Old Aug 25, 2007 | 04:47 PM
JaredKaragen's Avatar
injector battery offset could be your key....
SergioE92
May 21, 2013 06:35 PM
Mr.Death
Jun 14, 2009 07:35 PM
ericstambaugh07
Jan 20, 2007 01:52 AM
kornerk12
Oct 16, 2006 07:27 AM
Ri5e
Oct 9, 2004 07:41 AM
