extending oil pressure sensor wire.........
Old Jun 23, 2007 | 02:41 PM
thelate1's Avatar
Default extending oil pressure sensor wire.........
i'm using the fast turbo supply line kit. i was gonna move the oem oil pressure sensor up to the firewall were my oil "t" is. the wire is way too short, so i was going to just solder onto it. will this be ok, or is this like the o2 sensor wire, where i've heard you should never try to lengthen it. has anyone else done this, or do you guys just use the "L" fitting after the bspt adapter, and keep the sensor in the same area. is hondabond ok for the fitting joints?
thanx.
Old Jun 23, 2007 | 02:42 PM
A.E Motoring's Avatar
Default Re: extending oil pressure sensor wire......... (thelate1)
u can extend the pressure sensor wire, i have done it for my firewall kit
Old Jun 23, 2007 | 02:49 PM
thelate1's Avatar
Default Re: extending oil pressure sensor wire......... (Dual Cam Racing)
cool, thanx man! can i use a new bullet style connecter, instead of re-splicing on the old one?
Old Jun 23, 2007 | 02:55 PM
u can do it anyway u want, i just extended it, no connectors, works just fine
Old Jun 23, 2007 | 03:07 PM
thelate1's Avatar
thanx.
Old Jun 23, 2007 | 04:07 PM
RedEj8's Avatar
I would deffinately solder it.
Old Jun 23, 2007 | 09:38 PM
thelate1's Avatar
Default Re: extending oil pressure sensor wire......... (RedEj8)
soldered, and shrink wrapped! i should be good to go.
thanx.
jdubEP3
Jan 26, 2012 05:23 AM
Red_ED8
Nov 19, 2007 06:26 AM
White91EF
Jul 6, 2007 11:11 AM
