HKS SSQV Copper Line broken off (pic)??
Re: HKS SSQV Copper Line broken off (pic)?? (AEGturbo)
Since its technically a 'JDM' part, your solution has to be JDM. Seriously, if its between those two sizes, its probably 4mm - thats a fairly common metric size.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AEGturbo »</TD></TR><TR><TD CLASS="quote">The copper line where the vacuum line goes broke off my SSQV at an exhaust shop, and I've tried 1/8" copper line and it was too small and 3/16" is too big. Can I just JB Weld the 1/8" so it stays and ill be fine?
had same issue with my hks replica. i pushed it back in, then applied jb weld all around, then high temp black silicone.. no poblems after that. let it dry for couple days btw
Re: HKS SSQV Copper Line broken off (vtec.dc2)
my friends broke off as well, he just jb welded it and its staying. if i were you id ditch that garbage and pick up a tial 50mm
