For you turbo guys
Re: (lovey408)
Exedy stg I clutch and lightened b-series flywheel (balanced). 325whp on the clutch.......I am really surprised that it holds it to be honest.
Re: (rebo0t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rebo0t »</TD></TR><TR><TD CLASS="quote">competition clutch</TD></TR></TABLE>
ACT Heavy duty.
But just asking what kind of clutch/flywheel is kind of vague. Not a single clutch will perform best in any kind of set-up, simply because there are many variables to consider.
Also asking what type of set-up and how much power people are running would be a better question, also if it is a dd or strictly race.
GO GIANTS!
Re: For you turbo guys (turbotypeR@SPEC)
Yeah, I was just wondering if a Fidanza 7.5 lbs Flywheel would hold up on Boosted GSR motor. I will be running stage 4 Competition Clutch.
Re: For you turbo guys (HondamanXxX)
A heavy flywheel will usually work better on a turbo honda. What are you doing with the car? Drag, road race, etc?
Use a steel flywheel. It will have more inertia and help you come out of the hole better. It will also help keep the car from bogging between shifts.
GO GIANTS!
Also another question. I was thinking about putting the clutch in before I slapped the turbo on. Will it damage the motor or trans if I put a Competition Clutch Stage 4 on with out boost? The motor then will probably have around 200-220 hp? I am assuming it will.
There are some pics at: http://www.cardomain.com/ride/2210126
You should have no problem running that clutch without a turbo. I will try and find a video for ya.
Here is a video. My car is the one that runs the Buick at 10.4?
http://www.semotorsports.com/m...7.wmv
