Skunk @ Pro 1 cams going in tomorrow
Skunk 2 Pro 1 cams going in tomorrow
Specs: B16 84 mm sleeved 9:1 comp all work done by Javier at JG Engine Dynamics-Turbo Block with Pro Series Head with Oversized exhaust valves port and polish valve job the works...Best most experienced builder in my opinion http://www.jgenginedynamics.com Boost AC Ramhorn turbo kit from Phoenix Turbo http://www.cheapturbo.com 57 trimm T3/T4OE
thanks Ken...
And...JG Mani with SK2 Pro 1Turbo Cams all installed by UMS Tunning in Tempe,AZ and tuned by Tim at Xact Dyno with hondata s300 with gear based boost contol opt. Will hopefully post up dyno sheets with numbers tomorrow...all thats holding me back are the injectors getting them tomorrow along with cam install tomorrow...CANT WAIT! Nothing but good things for both shops !
SPECIAL THANX to Briann Over at Skunk 2 Customer Service for the hookup and awesome customer service/product suggestion for making this happen thanks bro... for Skunk2 best f'n company out there!!! Long time customer always will be!!! Thanks AGAIN!! Will Post Tomorrow....
thanks Ken...
Re: Skunk 2 Pro 1 cams going in tomorrow (PeakBoostSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PeakBoostSi »</TD></TR><TR><TD CLASS="quote">all work done by Javier at JG Engine Dynamics.....Best most experienced builder in my opinion </TD></TR></TABLE>
Good luck on your setup man.....but that guy is a crook.
Re: (PeakBoostSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PeakBoostSi »</TD></TR><TR><TD CLASS="quote">WHY??? </TD></TR></TABLE>
where have u been? ok i see 8 posts...do a search for jg engine dynamics and u will see why.
Guest
Posts: n/a
Nice setup...looks like you could make big power...I figure that turbo will limit you to around 500whp..
Best of luck..
Best of luck..
Re: Skunk 2 Pro 1 cams going in tomorrow (NTX)
Wow.... If I would have known these things before I sent my block out to him I prob. would not have done it...he did take longer then he promised to send me out the block...but I have nothing but good things to say...just hope that if anything goes wrong he will honor it..he still has a business to run and sometimes yeah people do fk up but I'm hoping his block will hold up...was ral healthy when i got it form him and just hope on making some good reliable power with his engine...Im nervous now that I hear all this I will stand behind his product 100% if it stands up to all he made it sound to be...
thanks for the compliments on the customer service. Make sure whoever is installing those cams sets the centerlines correct. Do you have oversize valves?
Re: Skunk 2 Pro 1 cams going in tomorrow (Skunk2Tony)
I HAVE ONE OF HIS BLOCKS RIGHT NOW ROD KNOCK,HE MACHINES THE BLOCK AND LEAVES PART OF THE HONDA SLEEVE WHICH IS SO THIN IT EVENTUALLY CRACKS GE,BENSON,AEBS, JG HE HAD MY BLOCK FOR 8 MONTHS GAVE ME ATTITUDE,TOLD ME I CAN TAKE MY BLOCK IF I DIDNT LIKE IT AFTER HE ALREADY CUT THE SLEEVES?? HES A JERK AND I HOPE HE HAS ANOTHER HEART ATTACK
